[GRASS-user] Problem with vdigit in 64 release
Hello,
I have a problem with vdigit (64svn). It compiles but doesn't work.
I can start vdigit (from map window) and get the icon set in the map
display. I can choose a map, but then nothing happens. I can not edit but
exit vdigit mode ok.
Python 2.5.4
wx-config --version-full 2.8.9.1
SWIG Version 1.3.38
gcc i686-pc-linux-gnu-4.3.3
I always do a 'make clean && make libsclean && distclean' prior to compiling
./configure --with-cairo --with-mysql
--with-mysql-includes=/usr/include/mysql --with-freetype
--with-freetype-includes=/usr/include/freetype2/
--with-fretype-lib=/usr/lib/ --with-python --with-sqlite --with-odcb
--with-readline --with-opengl --with-cxx --with-gdal --with-opengl
--with-regex --with-wxwidgets=/usr/bin/wx-config --with-postgres
wx-config is a symbolic link to wx-config-2.8
I have a symbolic link to _gdi_.so
/usr/lib/libgdi.so ->
/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so
I make clean and make vdigit in gui/wxpython/vdigit -- no errors there
I get the following error in the command output window:
  File "/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/t
oolbars.py", line 1067, in OnSelectMap
self.StartEditing(self.layers[selection])
oolbars.py", line 1099, in StartEditing
self.parent.digit = Digit(mapwindow=self.parent.MapWindow)
  File "/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/v
digit.py", line 685, in __init__
VDigit.__init__(self, mapwindow)
digit.py", line 223, in __init__
mapwindow)
  File "/usr/local/grass-6.4.0svn/etc/wxpython/vdigit/grass6
_wxvdigit.py", line 327, in __init__
this = _grass6_wxvdigit.new_Digit(*args)
TypeError
in method 'new_Digit', argument 2 of type 'wxWindow *'
any ideas? thanks,
kries
View this message in context: http://n2.nabble.com/Problem-with-vdigit-in-64-release-tp2321670p2321670.html
2009/2/13 kries <kries@gmx.at>:
make distclean is enough.
you don't need that. Wxvdigit uses local copy of PseudoDC.
mapwindow)
TypeError
any ideas? thanks,
well, see my last reply. Try to put some more debug messages,
recompile wxvdigit module, etc.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
hi,
I had some trouble with my system. Glibc wouldn't compile and I thought a
messed up system might be the cause of my problems with grass. I finally
fixed it, but my grass problems haven't changed.
will come up with more debug info asap.
thanks,
kries
View this message in context: http://n2.nabble.com/Problem-with-vdigit-in-64-release-tp2321670p2334565.html
there seems to be a problem with cairo rendering:
GUI D3/3: Command(): cmd='g.gisenv', wait=True, returncode=0, alive=False
GUI D3/3: Command(): cmd='g.proj -p', wait=True, returncode=0, alive=False
GUI D3/3: CreateTool(): tool=498, label=displaymap bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8961768> >
GUI D3/3: CreateTool(): tool=499, label=rendermap bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8961a28> >
GUI D3/3: CreateTool(): tool=500, label=erase bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8960c80> >
GUI D3/3: CreateTool(): tool=501, label=pointer bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x895f980> >
GUI D3/3: CreateTool(): tool=502, label=query bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x895fc58> >
GUI D3/3: CreateTool(): tool=503, label=pan bitmap=<wx._gdi.Bitmap; proxy
of <Swig Object of type 'wxBitmap *' at 0x8960e50> >
GUI D3/3: CreateTool(): tool=504, label=zoom_in bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8960e40> >
GUI D3/3: CreateTool(): tool=505, label=zoom_out bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8963038> >
GUI D3/3: CreateTool(): tool=506, label=zoom_back bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8963008> >
GUI D3/3: CreateTool(): tool=507, label=zoommenu bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8963090> >
GUI D3/3: CreateTool(): tool=508, label=analyze bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8960e60> >
GUI D3/3: CreateTool(): tool=509, label=overlay bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8960e70> >
GUI D3/3: CreateTool(): tool=510, label=savefile bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8961b60> >
GUI D3/3: CreateTool(): tool=511, label=printmap bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8962dc0> >
GUI D2/3: MapFrame.__InitDisplay():
GUI D2/3: Map.ChangeMapSize(): width=760, height=545
GUI D3/3: Command(): cmd='g.region -u -g -p -c', wait=True, returncode=0,
alive=False
GUI D3/3: Map.GetRegion(): {'rows': 12073.0, 'e': 655681.69999999995,
'cells': 101811609.0, 'cols': 8433.0, 'center_northing':
615211.34999999998, 'n': 1218877.2, 'center_easting': 234044.54999999999,
's': 11545.5, 'w': -187592.60000000001, 'ewres': 99.996952449999995,
'nsres': 100.00262569}
GUI D3/3: BufferedWindow.OnSize():
GUI D2/3: Map.ChangeMapSize(): width=758, height=503
GUI D3/3: Map.AdjustRegion(): {'rows': 503.0, 'e': 655681.69999999995,
'cells': 381274.0, 'cols': 758.0, 'center_northing': 615211.34999999998,
'n': 1218877.2, 'center_easting': 234044.54999999999, 's': 11545.5, 'w':
-187592.60000000001, 'ewres': 1112.4990765171503, 'nsres':
2400.2618290258447}
GUI D3/3: Map.SetRegion(): n-s resol: 2400.261829; n-s resol3:
18864.5578125; rows: 503; north: 1218877.2; t-b resol: 1; zone: 0; bottom:
-0.5; rows3: 64; west: -187592.6; top: 0.5; cols: 758; cols3: 128; depths:
1; e-w resol: 1112.499077; proj: 99; e-w resol3: 6588.08046875; east:
655681.7; south: 11545.5;
GUI D3/3: Command(): cmd='g.pnmcomp in= mask= opacity=
background=255:255:255 width=758 height=503 output=/tmp/tmpxfxQ_E.ppm',
GUI D2/3: Map.Render() force=True file=/tmp/tmpxfxQ_E.ppm
GUI D3/3: Map.GetListOfLayers(): numberof=0
GUI D2/3: BufferedWindow.UpdateMap(): render=True, renderVector=True ->
time=0.01
GUI D3/3: LayerTree().AddLayer(): ltype=vector
GUI D3/3: Layer.__init__(): type=vector, cmd='', name=None, active=1,
opacity=1, hidden=0
GUI D3/3: Map.AddLayer(): layer=None
GUI D3/3: LayerTree.PropertiesDialog(): ltype=vector
GUI D3/3: Map.ChangeLayer(): layer=None
GUI D3/3: Layer.SetCmd(): cmd=''
GUI D3/3: Command(): cmd='v.category input= option=report', wait=True,
returncode=1, alive=False
GUI D3/3: Map.GetListOfLayers(): numberof=1
GUI D3/3: Command(): cmd='v.db.connect -g --q map=BI3@kries', wait=True,
GUI D3/3: Command(): cmd='db.describe -c --q table=mysql.BI3 driver=mysql
database=mysql', wait=True, returncode=0, alive=False
GUI D3/3: Command(): cmd='v.category input=BI3@kries option=report',
GUI D3/3: Map.ChangeLayer(): layer=vector (double click to set properties)
GUI D3/3: Layer.SetCmd(): cmd='d.vect map=BI3@kries
type=point,area,face,centroid,line,boundary'
2400.2618290258447}
GUI D3/3: Layer.Render(): type=vector, name=BI3@kries
GUI D3/3: Command(): cmd='d.mon -p', wait=True, returncode=0, alive=False
GUI D3/3: Command(): cmd='d.mon start=cairo', wait=True, returncode=0,
alive=False
GUI D3/3: Command(): cmd='d.vect map=BI3@kries
type=point,area,face,centroid,line,boundary --q', wait=True, returncode=0,
alive=False
GUI D3/3: Command(): cmd='d.mon stop=cairo', wait=True, returncode=0,
alive=False
GUI D3/3: Map.Render() type=vector, layer=BI3@kries
GUI D3/3: Command(): cmd='g.pnmcomp in=/tmp/tmp6wI74I.ppm
mask=/tmp/tmp6wI74I.pgm opacity=1.0 background=255:255:255 width=758
height=503 output=/tmp/tmpxfxQ_E.ppm', wait=True, returncode=0,
alive=False
time=0.01
GUI D3/3: Map.AlignExtentFromDisplay(): width=758, height=503,
res=1240.691999, center=282049.786581,653615.539264
GUI D3/3: Map.AdjustRegion(): {'rows': 503.0, 'e': 752272.05423897947,
'cells': 381274.0, 'cols': 758.0, 'center_northing': 653615.53926441364,
'n': 965029.23103822395, 'center_easting': 282049.78658051678, 's':
342201.84749060328, 'w': -188172.48107794585, 'ewres': 1240.6919990988461,
'nsres': 1238.2254146075957}
GUI D3/3: Map.SetRegion(): n-s resol: 1238.225415; n-s resol3:
18864.5578125; rows: 503; north: 965029.231038; t-b resol: 1; zone: 0;
bottom: -0.5; rows3: 64; west: -188172.481078; top: 0.5; cols: 758; cols3:
128; depths: 1; e-w resol: 1240.691999; proj: 99; e-w resol3:
6588.08046875; east: 752272.054239; south:342201.847491;
alive=False
alive=False
alive=False
alive=False
time=0
res=693.110242, center=249791.794604,607089.589298
GUI D3/3: Map.AdjustRegion(): {'rows': 503.0, 'e': 512480.57633760094,
'cells': 381274.0, 'cols': 758.0, 'center_northing': 607089.58929820685,
'n': 781060.26005057408, 'center_easting': 249791.79460394682, 's':
433118.91854583961, 'w': -12896.987129707326, 'ewres': 693.11024204130388,
'nsres': 691.73228927382604}
GUI D3/3: Map.SetRegion(): n-s resol: 691.732289; n-s resol3:
18864.5578125; rows: 503; north: 781060.260051; t-b resol: 1; zone: 0;
bottom: -0.5; rows3: 64; west: -12896.9871297; top: 0.5; cols: 758; cols3:
128; depths: 1; e-w resol: 693.110242; proj: 99; e-w resol3:
6588.08046875; east: 512480.576338; south: 433118.918546;
alive=False
type=point,area,face,centroid,line,boundary --q', wait=True, returncode=1,
alive=False
/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/gcmd.py:63:
DeprecationWarning: BaseException.message has been deprecated as of Python
2.6
  self.message = message
/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/gcmd.py:70:
2.6
  message=self.message,
hm, don't know if that debug information is of any use.
the following log is from an attempt to start vdigit (no cairo):
          __________ ___ __________ _______________
         / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
        / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
       / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
       \____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS 6.4.0svn (2009)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.4.0svn (OS):~ > GUI D1/3: GMFrame.NewDisplay(): idx=0
proxy of <Swig Object of type 'wxBitmap *' at 0x89603b0> >
proxy of <Swig Object of type 'wxBitmap *' at 0x89619f8> >
proxy of <Swig Object of type 'wxBitmap *' at 0x8960e00> >
proxy of <Swig Object of type 'wxBitmap *' at 0x8960df0> >
proxy of <Swig Object of type 'wxBitmap *' at 0x8961b30> >
of <Swig Object of type 'wxBitmap *' at 0x8961940> >
proxy of <Swig Object of type 'wxBitmap *' at 0x8961930> >
proxy of <Swig Object of type 'wxBitmap *' at 0x8960e50> >
proxy of <Swig Object of type 'wxBitmap *' at 0x8960d20> >
proxy of <Swig Object of type 'wxBitmap *' at 0x8960d30> >
proxy of <Swig Object of type 'wxBitmap *' at 0x8961c68> >
proxy of <Swig Object of type 'wxBitmap *' at 0x8962f88> >
proxy of <Swig Object of type 'wxBitmap *' at 0x8961aa8> >
alive=False
2400.2618290258447}
background=255:255:255 width=758 height=503 output=/tmp/tmpcyqTN6.ppm',
GUI D2/3: Map.Render() force=True file=/tmp/tmpcyqTN6.ppm
time=0.01
opacity=1, hidden=0
GUI D3/3: Command(): cmd='d.mon -l', wait=True, returncode=0, alive=False
2400.2618290258447}
alive=False
GUI D3/3: Command(): cmd='g.pnmcomp in=/tmp/tmpYLY0jH.ppm
mask=/tmp/tmpYLY0jH.pgm opacity=1.0 background=255:255:255 width=758
height=503 output=/tmp/tmpcyqTN6.ppm', wait=True, returncode=0,
alive=False
time=0.01
GUI D3/3: CreateTool(): tool=515, label=digAddPoint
bitmap=<wx._gdi.Bitmap; proxy of <Swig Object of type 'wxBitmap *' at
0x8acabc8> >
GUI D3/3: CreateTool(): tool=516, label=digAddLine bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8aeb2e8> >
GUI D3/3: CreateTool(): tool=517, label=digAddBoundary
0x8938a78> >
GUI D3/3: CreateTool(): tool=518, label=digAddCentroid
0x8b1de78> >
GUI D3/3: CreateTool(): tool=519, label=digMoveVertex
0x8aeb338> >
GUI D3/3: CreateTool(): tool=520, label=digAddVertex
0x8b1de58> >
GUI D3/3: CreateTool(): tool=521, label=digRemoveVertex
0x8b33df0> >
GUI D3/3: CreateTool(): tool=522, label=digSplitLine
0x8b33d90> >
GUI D3/3: CreateTool(): tool=523, label=digEditLine
0x8b33da0> >
GUI D3/3: CreateTool(): tool=524, label=digMoveLine
0x8b33db0> >
GUI D3/3: CreateTool(): tool=525, label=digDeleteLine
0x8b359f0> >
GUI D3/3: CreateTool(): tool=527, label=digDispCats
0x8b35a00> >
GUI D3/3: CreateTool(): tool=529, label=digCopyCats
0x8b117f8> >
GUI D3/3: CreateTool(): tool=528, label=digDispAttr
0x8b35ed0> >
GUI D3/3: CreateTool(): tool=526, label=digAdditionalTools
0x8b35ee0> >
GUI D3/3: CreateTool(): tool=530, label=digUndo bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8afe820> >
GUI D3/3: CreateTool(): tool=531, label=digSettings
0x8afe810> >
GUI D3/3: CreateTool(): tool=532, label=digExit bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8b1d468> >
GUI D2/3: Map.ChangeMapSize(): width=758, height=463
GUI D3/3: Map.AdjustRegion(): {'rows': 463.0, 'e': 655681.69999999995,
'cells': 350954.0, 'cols': 758.0, 'center_northing': 615211.34999999998,
2607.6278617710582}
GUI D3/3: Map.SetRegion(): n-s resol: 2607.627862; n-s resol3:
18864.5578125; rows: 463; north: 1218877.2; t-b resol: 1; zone: 0; bottom:
alive=False
height=463 output=/tmp/tmpcyqTN6.ppm', wait=True, returncode=0,
alive=False
time=0.02
2607.6278617710582}
alive=False
alive=False
time=0
2607.6278617710582}
alive=False
alive=False
time=0.02
GUI D3/3: Map.ChangeLayerActive(): name='BI3@kries' -> active=0
GUI D3/3: AbstractDigit.__init__(): map=None
  File "/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/toolbars.py",
  File "/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/vdigit.py",
    mapwindow)
  File "/usr/local/grass-6.4.0svn/etc/wxpython/vdigit/grass6_wxvdigit.py",
TypeError: in method 'new_Digit', argument 2 of type 'wxWindow *'
grass70 fails to draw vector map (cairo):
Welcome to GRASS 7.0.svn (2009)
This version running through: Bash Shell (/bin/bash)
GRASS 7.0.svn (OS):~ > GUI D1/3: GMFrame.NewDisplay(): idx=0
GUI D3/3: CreateTool(): tool=501, label=displaymap bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x895e308> >
GUI D3/3: CreateTool(): tool=502, label=rendermap bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x895e098> >
GUI D3/3: CreateTool(): tool=503, label=erase bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x895e218> >
GUI D3/3: CreateTool(): tool=504, label=pointer bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x895e208> >
GUI D3/3: CreateTool(): tool=505, label=query bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8960a40> >
GUI D3/3: CreateTool(): tool=506, label=pan bitmap=<wx._gdi.Bitmap; proxy
of <Swig Object of type 'wxBitmap *' at 0x8960ac0> >
GUI D3/3: CreateTool(): tool=507, label=zoom_in bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8960ab0> >
GUI D3/3: CreateTool(): tool=508, label=zoom_out bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x895e3d8> >
GUI D3/3: CreateTool(): tool=509, label=zoom_back bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x895e3e8> >
GUI D3/3: CreateTool(): tool=510, label=zoommenu bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x895edf0> >
GUI D3/3: CreateTool(): tool=511, label=analyze bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8960ad0> >
GUI D3/3: CreateTool(): tool=512, label=overlay bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x895ed10> >
GUI D3/3: CreateTool(): tool=513, label=savefile bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x895ed50> >
GUI D3/3: CreateTool(): tool=514, label=printmap bitmap=<wx._gdi.Bitmap;
proxy of <Swig Object of type 'wxBitmap *' at 0x8960878> >
  File
"/usr/local/grass-7.0.svn/etc/wxpython/gui_modules/mapdisp_window.py",
line 442, in OnPaint
    self.pdc.DrawToDCClipped(dc, rgn)
  File "/usr/local/grass-7.0.svn/etc/wxpython/vdigit/grass7_wxvdigit.py",
line 386, in DrawToDCClipped
    def DrawToDCClipped(self, *args): return
_grass7_wxvdigit.PseudoDC_DrawToDCClipped(self, *args)
NotImplementedError: Wrong number of arguments for overloaded function
'PseudoDC_DrawToDCClipped'.
  Possible C/C++ prototypes are:
    DrawToDCClipped(gwxPseudoDC *,wxBufferedPaintDC *,wxRect const &)
    DrawToDCClipped(gwxPseudoDC *,wxGCDC *,wxRect const &)
2400.2618290258447}
GUI D2/3: Map.Render() force=True file=/tmp/tmpLHU69C.ppm
  File
line 534, in OnIdle
    self.UpdateMap(render=True)
  File
line 659, in UpdateMap
    self.Draw(self.pdc, self.img, drawid=id)
  File
line 263, in Draw
    pdc.SetBackground(bg)
line 378, in SetBackground
    def SetBackground(self, *args): return
_grass7_wxvdigit.PseudoDC_SetBackground(self, *args)
TypeError: in method 'PseudoDC_SetBackground', argument 2 of type 'wxBrush
const &'
opacity=1, hidden=0
  File
  File
2400.2618290258447}
  File "/usr/local/grass-7.0.svn/etc/wxpython/gui_modules/mapdisp.py",
line 560, in OnRender
    self.MapWindow.UpdateMap(render=True)
  File
  File
line 263, in Draw
const &'
  File
thanks for your help,
do you need more info?
kries
View this message in context: http://n2.nabble.com/Problem-with-vdigit-in-64-release-tp2321670p2337117.html
