[GRASS-user] Problemas con winGRASS 6.4.0RC3 del instalador OSGeo4W
Saludos, me anime a descargar el instalador OSGeo4W que trae GRASS para Windows entre muchas otras cosas, tal como me recomendaron. Lo instalé y al abrir GRASS me dio un error al no estar predefinido el directorio de datos, estuve revisando a ver si encontraba una carpeta que el instalador creara para tal fin, pero no la halle, realmente la crea?..Decidí crear mi propio directorio, copie una locación de prueba, pero GRASS me arroja el siguiente error:
Erro setting region (Problem with g.region?): child lilled:unknown signal
Agradezco a quien pueda ayudarme…
Marilena
Get news, entertainment and everything you care about at Live.com. Check it out!
Invite your mail contacts to join your friends list with Windows Live Spaces. It’s easy! Try it!
please consider this is international ML (for those who cannot speak Spanish).
Martin
2009/2/11 Marilena Yeguez <myeguez@hotmail.com>:
creara para tal fin, pero no la halle, realmente la crea?...Decidí crear mi
siguiente error:
Agradezco a quien pueda ayudarme...
Marilena
out!
Spaces. It's easy! Try it!
grass-user mailing list
grass-user@lists.osgeo.org
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
I confirm that error on old latlong location (created over 1 years ago, I didn't use it since that time)
due to this error gis.m cannot start, but grass still working in the text mode Addational masage in text console are:
Error in startup script: can't read "monitor_zooms(1,1,n)": no such variable
    while executing
"lappend region $monitor_zooms($mon,1,$attr)"
    (procedure "MapCanvas::currentzoom" line 15)
    invoked from within
"MapCanvas::currentzoom $mon"
    (procedure "MapCanvas::coordconv" line 23)
    invoked from within
"MapCanvas::coordconv $mon"
    (procedure "MapCanvas::create" line 68)
    invoked from within
"MapCanvas::create"
    (procedure "Gm::startmon" line 11)
    invoked from within
"Gm::startmon"
    (procedure "Gm::create" line 79)
    invoked from within
"Gm::create"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.4.svn/etc/gm/gm.tcl" line 566)
Jarek
Marilena Yeguez pisze:
Saludos, me anime a descargar el instalador OSGeo4W que trae GRASS para Windows entre muchas otras cosas, tal como me recomendaron. Lo instalé y al abrir GRASS me dio un error al no estar predefinido el directorio de datos, estuve revisando a ver si encontraba una carpeta que el instalador creara para tal fin, pero no la halle, realmente la crea?...Decidí crear mi propio directorio, copie una locación de prueba, pero GRASS me arroja el siguiente error:
Marilena
Get news, entertainment and everything you care about at Live.com. Check it out! <http://www.live.com/getstarted.aspx&gt;
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy! Try it! <http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us&gt;
  while executing
This is typically a GDAL problem.
What does
  g.region -p
say? Please test this since you can use GRASS in text mode.
g.region says:
EROR:Invalid ellipsoid '�' in file PROJ_INFO in <PERMANENT>
I removed PROJ_INFO and now grass can be used in gui (gis.m) mode
thanks for tip
Jarek
Markus Neteler pisze:
  while executing
What does
  g.region -p
On Mon, Feb 16, 2009 at 6:05 PM, Jarek Jasiewicz <jarekj@amu.edu.pl> wrote:
g.region says:
EROR:Invalid ellipsoid '� ' in file PROJ_INFO in <PERMANENT>
How was the PROJ_INFO file generated?
Which projection?
thanks for tip
It's no good to remove the file since you lose the spatial
reference. Better to actually correct it...
g.region says:
Which projection?
Sorry I don' rememer it was over one year ago.
projection lato long based on WGS84 elipsoid
thanks for tip
