Hello!
I have tried to install gem (Benjamin Ducke's extension manager) and some
extensions onto my linux box (AMD 64, Suse 9.3). But I get errors after
installing the extensions when I try to start GRASS with the gis.m graphic
interface. See below. I'm no expert on tcl; but from the errormessage I get
the impression that it is an error in gis.m. gem seems to mess up the menu
system!
I've CC'ed Benjamin (two adresses).
If this is a bug related to suse 9.3, I will consider an upgrade to suse 10.1
GRASS 6.1.0RC1 compiled successfully; and gis.m worked before using gem to try
to install the extensions (advancedstatistics and rastertools - both latest
release from Benjamins site). I did not try to install any further
extensions.
Regards
larsf
Output from GRASS startup - xterm:
Welcome to GRASS 6.1.0RC1 (2006)
GRASS homepage: http://grass.itc.it/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the graphical user interface with: gis.m &
When ready to quit enter: exit
GRASS 6.1.0RC1 (leka):~ > Error in startup script: unmatched open brace in
list
while executing
"llength $entry"
(procedure "_create_entries" line 7)
invoked from within
"_create_entries $path $menu $bg $entries"
(procedure "_create_menubar" line 34)
invoked from within
"_create_menubar $path $menu"
(procedure "MainFrame::create" line 63)
invoked from within
"MainFrame::create .mainframe -menu {&File all file 1 {
{cascad {Workspace} {} "" 1 {
{command {Open...} {} "Open gis.m workspace file" {} -acc..."
("eval" body line 1)
invoked from within
"eval MainFrame::create $path $args"
(procedure "MainFrame" line 1)
invoked from within
"MainFrame .mainframe -menu $descmenu -textvariable Gm::status -progressvar
Gm::prgindic "
(procedure "Gm::create" line 32)
invoked from within
"Gm::create"
(procedure "main" line 30)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.1.0RC1/etc/gm/gm.tcl" line 528)
