Here, I report more information:
v.info JCE_M2006
| Layer: JCE_M2006 |
| Mapset: user1 |
| Database: /home/omar/grassdata |
| Title: |
| Map scale: 1:1 |
| Map format: native |
| Name of creator: |
| Organization: |
| Source date: |
| Type of Map: vector (level: 2) |
| Number of points: 0 Number of areas: 9909 |
| Number of lines: 0 Number of islands: 8 |
| Number of boundaries: 20227 Number of faces: 0 |
| Number of centroids: 5078 Number of kernels: 0 |
| Map is 3D: No |
| Number of dblinks: 1 |
| Projection: Unknown projection |
| N: 2204990.860491 S: 1941029.08979587 |
| E: 571289.72171435 W: 182391.61052347 |
| Digitization threshold: 0 |
| Comments: |
db.describe table=JCE_M2006 driver=db
table:JCE_M2006
description:
insert:yes
delete:yes
ncols:31
nrows:151
column:CAT
description:
type:INTEGER
len:19
scale:0
precision:18
default:
nullok:yes
select:yes
update:yes
column:COD_JCE_M
description:
type:CHARACTER
len:3
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:CODIGO
description:
type:CHARACTER
len:8
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:COD_JCE_P
description:
type:CHARACTER
len:2
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:PROVINCIA
description:
type:CHARACTER
len:22
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:MUNICIPIO
description:
type:CHARACTER
len:26
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:A_GANADORA
description:
type:CHARACTER
len:5
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:ALIANZATRI
description:
type:CHARACTER
len:8
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:ALIANZAMAX
description:
type:DOUBLE PRECISION
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:R_ALIANZAM
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:RD_ALIANZA
description:
len:4
scale:2
precision:2
default:
nullok:yes
select:yes
update:yes
column:ALIANZAMIN
description:
type:CHARACTER
len:9
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:ALIANZAMI2
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:R_ALIANZA2
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:PARTIDOMAX
description:
type:CHARACTER
len:8
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:PARTIDOMA2
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:R_PARTIDOM
description:
len:4
scale:2
precision:2
default:
nullok:yes
select:yes
update:yes
column:RD_PARTIDO
description:
len:4
scale:2
precision:2
default:
nullok:yes
select:yes
update:yes
column:MINOR_AMAX
description:
type:CHARACTER
len:9
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:MINORIAMAX
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:R_MINORIAM
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:C_VOTOS
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:P_VOTOS
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:T_INSCRITO
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:V_EMITIDOS
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:P_VOTANTES
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:C_ABSTENCI
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:P_ABSTENCI
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:ESPACIAL_C
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:ESPACIAL_A
description:
len:4
scale:2
precision:2
default:
nullok:yes
select:yes
update:yes
column:ESPACIAL_P
description:
len:4
scale:2
precision:2
default:
nullok:yes
select:yes
update:yes
2009/12/9 Omar Bautista González <omarbautistag@gmail.com>:
I tested, the same command on an older version of GRASS and it worked
(6.2.3). So I think this is a bug on this recent version (6.4.0RC5).
I also tried simpler commands with d.vect.thematic and didn't worked
with 6.4.0RC5. These commands worked well on 6.2.3.
¿What can we do to solve this module? I'm not programming on C now. If
I would I'll try to figure out some changes on d.vect.thematic module.
Att.
2009/12/7 Omar Bautista González <omarbautistag@gmail.com>:
Hello:
The problem is with the d.vect.thematic command. It don't display
nothing on the monitor. Even when other commands do it right.
I did the following commands:
d.mon x0
d.vect.thematic -s map=JCE_M2006 type=area column=RD_ALIANZA layer=1 icon=basic/circle size=5 maxsize=20 nint=4 pointcolor=255:0:0 linecolor=0:0:0 startcolor=255:0:0 endcolor=0:0:255 themetype=graduated_colors monitor=none themecalc=interval colorscheme=blue-red;
And nothing is displayed. Here are the output errors:
Segmentation fault
Thematic map legend for column RD_ALIANZA of map JCE_M2006
Value range: -
Mapped by 4 intervals of -inf
Color(R:G:B) Value
0:0:255 -
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected AND processing 'and'
in statement:
SELECT cat FROM JCE_M2006 WHERE RD_ALIANZA >= and RD_ALIANZA<=
Error in db_open_select_cursor()
85:0:170 -
in statement:
SELECT cat FROM JCE_M2006 WHERE RD_ALIANZA > and RD_ALIANZA<=
170:0:85 -
in statement:
255:0:0 -
in statement:
I installed ubuntu 6.10 on a Dell Mini 10. Then from the repositories
I installed GRASS 6.4.0RC5.
This is very strange because other commands are displaying well. Like
the following:
d.vect.chart map=PuntosCentralesM2006
type=point,line,boundary,centroid layer=1
columns=C_PLD,C_PRD,C_PRSC,C_OTROS ctype=pie ocolor=black
sizecol=P_OTROS size=15 scale=1 colors=purple,white,red,yellow;
I tried also with the GUI having the same problem.
- Coordinador de Investigación para el Desarrollo,
Diseño, Monitoreo y Evaluación
Visión Mundial República Dominicana
