[GRASS-user] Problems exporting Shapefiles
Hello everyone,
I have some problems exporting to shapefiles. When I try to export, I get these errors:
This first shows when I try to export only naming a file… “output= boundaries.shp”
Check if OGR layer <ne_10m_populated_places_simple> contains polygons…
DBMI-SQLite driver error:
Unable to open database: C:\Users\xxxxxxx\Documents\grass
data\nc_spm_08_grass7\PERMANENT\sqlite\sqlite.db
unable to open database file
WARNING: No ha sido posible abrir la base de datos <C:\Users\xxxxxxx\Documents\grassdata\nc_spm_08_grass7\PERMANENT\sqlite\sqlite.db> con el controlador <sqlite>.
ERROR: No se puede abrir la base de datos <C:\Users\xxxxxx\Documents\grassdata\nc_spm_08_grass7\PERMANENT\sqlite\sqlite.db> por el controlador <sqlite>
This other one, shows when I indicate only a route: "output=C:\Users\xxxxxxx\Documents"
ERROR 1: Failed to create directory
C:\Users\xxxxxxx\Documents</small>
for shapefile datastore.
ERROR: No se puede abrir entrada de datos OGR 'C:\Users\LuísMiguel\Documents'
I’m using Windows 8.1, and GRASS 7.01RC2.
Anyone has any idea what’s happening?
Thank you per advance!!
