[GRASS-user] Problems running g.gui.gcp
Dear GRASS users,
Today I wanted to try the georectification tool g.gui.gcp in GRASS 7 for the first time. I was basically following the description on the GRASS wiki (https://grasswiki.osgeo.org/wiki/Georeferencing). In particular, I have a photograph from my camera with known reference points which I load into an unprojected XY location. My target location should also be a XY location as the picture is taken from a “virtual” coordinate system. Inside my target XY-location I try to open g.gui.gcp and select raster, and the location and mapset where my photograph is stored. When I want to click next I get following error/message: “You must select a valid location and mapset in order to continue” and I can’t proceed with the rectification. Just this GUI message appears, no error/warning in the grass console etc. I am puzzled how to interpret that? What is wrong with the location/mapset? The mapset I’ve selected is existing (I can select it from the dropdown menu). I tried to select any other location/mapset but receive always the same message.
I am running GRASS 7.0.2 on Ubuntu:
GRASS version: 7.0.2svn
GRASS SVN Revision: 66568
Build Date: 2015-10-22
Build Platform: i686-pc-linux-gnu
GDAL/OGR: 1.10.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.9
Python: 2.7.3
wxPython: 2.9.4.1
Platform: Linux-3.2.0-92-generic-pae-i686-with-Ubuntu-12.04-precise
Any ideas?
Thanks!
/Johannes
On 22/10/15 16:25, Johannes Radinger wrote:
Dear GRASS users,
a XY location as the picture is taken from a "virtual" coordinate
I want to click next I get following error/message: "You must select a
valid location and mapset in order to continue" and I can't proceed with
with the location/mapset? The mapset I've selected is existing (I can
Georectification is for georeferencing to a projected system. It does not make sense to georeference to an XY-location.
I see two options for you:
- Import you image directely into the target region and use r.region to adjust its boundary coordinates
- Define your own projection system to fit your needs.
Moritz
On Fri, Oct 23, 2015 at 10:17 AM, Moritz Lennert <
Dear GRASS users,
So far as I understand georectification and orthorectification in
particular is to rectify a picture/photo/image based on spatially defined
ground control points which might not be done by just adjusting the
boundary coordinates. BTW I also tried the European LAEA coordinate system
(EPSG 3035) as a target location which is not working either here in my
machine/setup (same message as already mentioned). Here (
https://www.dropbox.com/s/snjzd8eu7b8115k/2015-10-22%2015.26.30.jpg?dl=0)
you can find a a photo (*.jpg) which is an "areal" photo with known 3d
coordinates for the single points (ground control points). I think this
example clarifies and illustrates what I intend to do and why the target
system can also be a XY location in my opinion. A rectification of this
image should make the lines of the grid more or less parallel. Or do I get
something completely wrong?
/Johannes
Moritz
        Dear GRASS users,
        GRASS 7 for
        particular, I
        also be
        select
        stored. When
        select a
        proceed with
        error/warning in
        is wrong
        (I can
defined ground control points which might not be done by just adjusting
the boundary coordinates. BTW I also tried the European LAEA coordinate
system (EPSG 3035) as a target location which is not working either here
in my machine/setup (same message as already mentioned). Here
(https://www.dropbox.com/s/snjzd8eu7b8115k/2015-10-22%2015.26.30.jpg?dl=0)
get something completely wrong?
Actually, I was wrong: I don't get any complaint trying to use g.gui.gcp to georectify from XY to XY. So there seems to be an issue with your XY locations.
Have you tried recreating the locations from scratch ?
Moritz
On Fri, Oct 23, 2015 at 11:19 AM, Moritz Lennert <
        Dear GRASS users,
        GRASS 7 for
        particular, I
which I
        also be
        select
        stored. When
        select a
        proceed with
        error/warning in
        is wrong
        (I can
locations.
Your results look really reasonable.... that's what I was looking for...
Actually, both XY locations are created from scratch (via the location
wizzard)
I get following output for both XY locations:
g.proj -p
XY location (unprojected)
I tried to start the GCP manager from within different other locations
(e.g. laea, datum: etrs89) and selecting different source location (e.g.
WGS84)....however I always get the same message. So I guess this is not
specifically related to my location but rather to the GCP manager/WX GUI?
As I don't get an error message it is difficult to judge what is going
wrong in my case...
I just looked up the source code and the error message seems to be related
to follwoing line:
https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/gui/wxpython/gcp/manager.py#L399
As far as I understand, this error message is only given if no
location/mapset is provided; however that is not the case here. Maybe my
selection of the location/mapset via the GUI does not get parsed
further....?
Strange that orthorectification from one XY to antother XY location works
on other machines but not on mine.
PS: As an important side note: I am working on Ubuntu which is installed on
a virtual machine (VMWare) on our server. I remotely connect to this
virtual machine via RDP.
Moritz
On Oct 23, 2015 6:04 AM, “Johannes Radinger” <johannesradinger@gmail.com> wrote:
On Fri, Oct 23, 2015 at 11:19 AM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
<mlennert@club.worldonline.be mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)> wrote:
Dear GRASS users,
GRASS 7 for
particular, I
also be
select
stored. When
select a
proceed with
error/warning in
is wrong
(I can
  • Import you image directely into the target region and use r.region
  • Define your own projection system to fit your needs.
you can find a a photo (*.jpg) which is an “areal” photo with known 3d
Actually, I was wrong: I don’t get any complaint trying to use g.gui.gcp to georectify from XY to XY. So there seems to be an issue with your XY locations.
Your results look really reasonable… that’s what I was looking for…
Actually, both XY locations are created from scratch (via the location wizzard)
g.proj -p
I tried to start the GCP manager from within different other locations (e.g. laea, datum: etrs89) and selecting different source location (e.g. WGS84)…however I always get the same message. So I guess this is not specifically related to my location but rather to the GCP manager/WX GUI? As I don’t get an error message it is difficult to judge what is going wrong in my case…
I just looked up the source code and the error message seems to be related to follwoing line:
As far as I understand, this error message is only given if no location/mapset is provided; however that is not the case here. Maybe my selection of the location/mapset via the GUI does not get parsed further…?
Strange that orthorectification from one XY to antother XY location works on other machines but not on mine.
PS: As an important side note: I am working on Ubuntu which is installed on a virtual machine (VMWare) on our server. I remotely connect to this virtual machine via RDP
I noticed you have strange version of wxpython. Any chance you could test on machine with version 2.8.12.0 or a stable 3 version?
Anna
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
On Fri, Oct 23, 2015 at 1:37 PM, Anna Petrášová <kratochanna@gmail.com>
wrote:
On Oct 23, 2015 6:04 AM, "Johannes Radinger" <johannesradinger@gmail.com>
>>> Dear GRASS users,
>>> GRASS 7 for
the
>>> GRASS
>>> particular, I
which I
>>> also be
coordinate
and
>>> select
>>> stored. When
>>> select a
>>> proceed with
>>> error/warning in
>>> is wrong
>>> (I can
r.region
here
target
your XY locations.
wizzard)
> g.proj -p
wrong in my case...
further....?
Indeed, I upgraded now to wxpython 3.0.1.0 and the GCP manager is working
now! YES!. At least my location/mapset settings are accepted and I get to
the next step. So now I can actually test and try the GCP manager.
Thanks for your help!
/Johannes
Anna
>> Moritz
