[GRASS-user] Problems to install Grass7 on Fedora 12 -64
Dear all,
I am trying to install Grass7 on my Fedora12 but I always have the same error message:
[root@localhost GRASS7]# sh grass-7.0.svn-i686-pc-linux-gnu-24_04_2010-install.sh --help
GRASS GIS 7.0.svn-i686-pc-linux-gnu-24_04_2010 binary package installation tool
Usage: grass-7.0.svn-i686-pc-linux-gnu-24_04_2010-install.sh grass-7.0.svn-i686-pc-linux-gnu-24_04_2010.tar.gz [dest_dir] [bin_dir]
with:
[dest_dir] - optional: FULL path name to the installation directory
(default: /usr/local/grass7.0.svn-i686-pc-linux-gnu-24_04_2010/)
[bin_dir] - optional: FULL path name to the grass binary directory
(default: /usr/local/bin/)
Notes: 1) Only the grass executable file is stored here
2) If you want to change the binary directory only
then you need to specify the destination
directory as well
You may need login as root for installation.
I was logged as root (in this case, using su in a console window, but I tried even logged as root on a KDE GUI and logged as root in command line mode (init3).
Can you point to me what I am doing wrong?
Adalberto
