I see what's happening - when you use the QGIS Processing plugin, it creates a temporary DATABASE path to do its work. GRASS.app remembers this, but since it's temporary within QGIS, it no longer exists for GRASS.app.
When you use GRASS.app by itself, you need to fill in the DATABASE also. Alternately, drag the MAPSET folder onto GRASS.app to start GRASS, it will automatically open the mapset and fill in the correct LOCATION and DATABASE path.
On Mar 11, 2014, at 9:11 AM, José Carlos Guerrero Antúnez wrote:
Yes, and it's displayed the following:
'/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
Last login: Tue Mar 11 10:01:14 on console
102:~ joseca_IMac$ '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.6.1 found.
Cleaning up temporary files ...
Starting GRASS ...
access: No such file or directory
ERROR: LOCATION <<
/var/folders/ZI/ZILrLuSdG3uvcRwKJxojRU+++TI/-Tmp-/processing/grassdata/temp_location
>> not available
GRASS 6.4.3
DATABASE: A directory (folder) on disk to contain all GRASS maps and data.
LOCATION: This is the name of a geographic location. It is defined by a
co-ordinate system and a rectangular boundary.
MAPSET: Each GRASS session runs under a particular MAPSET. This consists of
a rectangular REGION and a set of maps. Every LOCATION contains at
least a MAPSET called PERMANENT, which is readable by all sessions.
The REGION defaults to the entire area of the chosen LOCATION.
You may change it later with the command: g.region
LOCATION: temp_location____________ (enter list for a list of locations)
MAPSET: PERMANENT________________ (or mapsets within a location)
DATABASE: /var/folders/ZI/ZILrLuSdG3uvcRwKJxojRU+++TI/-Tmp-/processing/grassdat
When I write LOCATION and MAPSET, it's the message:
DATABASE </var/folders/ZI/ZILrLuSdG3uvcRwKJxojRU+++TI/-Tmp-/processing/grassdata> - not found
HIT RETURN
2014-03-11 11:01 GMT-03:00 William Kyngesburye <woklist@kyngchaos.com>:
Does Terminal.app start?
On Mar 6, 2014, at 1:58 PM, José Carlos Guerrero Antúnez wrote:
> Hi,
> When I launch GRASS GIS, must be appear the startup screen, but doesn't open it.
> All plugin are updated, I installed GRASS today from kynchaos web.
> Any help/advice?,
> Thank you,
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
Dr. José Carlos Guerrero
Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio (LDSGAT)
Instituto de Ecología y Ciencias Ambientales (IECA)
Facultad de Ciencias
Universidad de la República
Montevideo-URUGUAY
grass-user mailing list
grass-user@lists.osgeo.org
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
