When I try to launch QGIS (1.7.2) from within GRASS, I receive the following:
bash: qgis: command not found
Welcome to GRASS 6.4.1 (2011)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui tcltk
When ready to quit enter: exit
GRASS 6.4.1 (Sudamérica):~ > qgis
Thank you very much,
Dr. José Carlos Guerrero
Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio (LDSGAT)
Instituto de Ecología y Ciencias Ambientales (IECA)
Facultad de Ciencias
Universidad de la República
Montevideo-URUGUAY
2011/12/10 José Carlos Guerrero Antúnez <jcgantunez@gmail.com>:
following:
Please check the path to QGIS from where you commonly start it.
That may be the menu or elsewhere. If the path in not listed
in the $PATH variable, then please post it here and also the output
of
echo $PATH
from *within* a GRASS session. Then it will be easy to solve that.
following:
of
echo $PATH
from within a GRASS session. Then it will be easy to solve that.
