William Hudspeth:
I am using i.worldview.toar with the latest version of GRASS 7.3. I was
able to successfully download and install this extension. I have tried
using the module with the following input and error. All of the input
files exist, and I get an error stating that "No data base element files
found". Help appreciated...
i.worldview.toar
band=worldview2_b1_RED@worldview2,worldview2_b2_GREEN@worldview2,worldview2_b3_BLUE@worldview2,worldview2_b4_NIR@worldview2
outputsuffix=toar utc=2010-04-11T18:07:06.558405Z doy=101 sea=60.3
Nikos Alexandris:
Do you really need the 'worldview2' prefix for your band names? It's
identical to your Mapset's name. This is what a mapset is meant (or can
be used) for: a set of maps. In this case, it's a set of 'worldview2'
"maps".
Would you rename your bands and try again?
i.worldview.toar band=b1_RED,b2_GREEN,b3_BLUE,b4_NIR outputsuffix=toar
William Hudspeth:
I have given the bands simpler names, have re-run i.worldview.toar, and
am getting the same error:
i.worldview.toar
band=b1_red@worldview2,b2_green@worldview2,b3_blue@worldview2,b4_nir@worldview2
|! Using Day of Year to calculate Earth-Sun distance.
|! Region matching the b1_red@worldview2 spectral band
|* Processing the b1_red@worldview2 band
File
"/home/wilbur/.grass7/addons/scripts/i.worldview.toar", line
416, in <module>
sys.exit(main())
File
320, in main
acf = float(CF_BW_ESUN[band][2])
KeyError: 'b1_red'
WARNING: No data base element files found
William,
apologies for the inconvenience. I now had a better look and remember what is
what. Comments from the code itself:
Factors for Conversion to Top-of-Atmosphere Spectral Radiance
(absolute radiometric calibration factors)
Structure of the dictionary:
- Key: Name of band
- Items in tupple(s):
- 1st: Absolute Calibration Factors
- 2nd: Spectral Band's Effective Bandwidth, Δλ
- 3rd: Band-Averaged Solar Spectral Irradiance [W/sq.m./micro-m]
Retrieving values:
band = <Name of Band>
K[band][0] # for Effective Bandwidth
K[band][1] # for Esun
K[band][2] # for Absolute Conversion Factor
which are stored in the following python dictionary:
CF_BW_ESUN = {
'Pan': (0.28460000, 1580.8140, 0.056783450),
'Coastal': (0.04730000, 1758.2229, 0.009295654),
'Blue': (0.05430000, 1974.2416, 0.012608250),
'Green': (0.06300000, 1856.4104, 0.009713071),
'Yellow': (0.03740000, 1738.4791, 0.005829815),
'Red': (0.05740000, 1559.4555, 0.011036230),
'RedEdge': (0.03930000, 1342.0695, 0.005188136),
'NIR1': (0.09890000, 1069.7302, 0.012243800),
'NIR2': (0.09960000, 861.2866, 0.009042234)}
The module is flexible to request for any of the bands to be
converted. Yet, it has the disatvanage that requires the very name(s) of the
corresponding "key(s)" to access the respective calibration factors.
In short, rename your bands to exactly 'Red', 'Green', 'Blue', 'NIR'. Maybe this can be
changed, but I wouldn't have the time at the moment for it.
If you have any changes, already, please make a pull request in the github repository.
Nikos
Nikos
