[GRASS-user] Problems with actual grass6.3.cvs
Hello all,
I have compiled the actual grass6.3.cvs
When I start it, it hangs up at the start screen of the gis.m gui.
Working on Ubuntu 7.10
sun 64 bit
Best regards and wishes
Manuel
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent Scientific Assistant
Physische Geographie Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften Geography/Geosciences
Universität Trier University of Trier
D - 54286 Trier
Tel.: +49-651-201 4557
Fax: +49-651-201 3976
Web: http://www-neu.uni-trier.de/index.php?id=9607
Dr. Manuel Seeger pisze:
Hello all,
sun 64 bit
Manuel
looks like well-known problem of make distclean
Jarek
(Excuse me Jarosław forindividual answer before)
Here the output after error message:
GRASS 6.3.0RC3 (Attert_Praktikum):~ > Error in startup script: can't read "parts(w)": no such variable
    while executing
"set $parts(w) [expr round($parts(w)/$parts(ewres))*$parts(ewres)]"
    (procedure "MapCanvas::zoom_gregion" line 16)
    invoked from within
"MapCanvas::zoom_gregion $mon"
    (procedure "MapCanvas::create" line 40)
    invoked from within
"MapCanvas::create"
    (procedure "Gm::startmon" line 11)
    invoked from within
"Gm::startmon"
    (procedure "Gm::create" line 79)
    invoked from within
"Gm::create"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.3.0RC3/etc/gm/gm.tcl" line 633)
Maybe someone knows what went wrong.
Grass6.2.2 works fine with same location and mapset on the machine.
Regrds
Manuel
Hello all,
sun 64 bit
Manuel
Jarek
Tahnks Jarek,
but:
Same Problem with 6.3RC3
ran make distclean
how can I solve?
Manuel
in grass source dir
make distclean // it clean your prevoious makefiles
./configure --with ..... (or use your configure setup)
make
make install
Dr. Manuel Seeger
D - 54286 Trier
> sun 64 bit
    while executing
    invoked from within
I seems that g.region has failed for some reason. (still no test to
catch that cleanly?!)
can you start grass with
grass63 -text
then try 'g.region -p' from the command line and see if you get
reasonable output.
What flavour of Sun hardware? Self compiled?
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
