I have some questions concerning the behaviour of gparser.
In the attachment you can find a example-python-script.
Somehow the output from gparser for X (see script) is strange: I try
to use it in a if-command but somehow I fail.
The output when X is set to 'A a' should be a "juhuu" but it isn't.
I was looking for the bug in my code but somehow I couldn't find it.
When I replace the options for X with A,B and C (single Letters), it
seems to work...Is there a problem with spaces in the options of gparser?
I am working on GRASS6.5SVN on Mac OS X 10.6.8.
Can anyone try the script and reproduce the error? Does anyone have ideas where the problem in the script is located?
Thank you for your help.
Best regards,
Johannes
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://mobile.1und1.de/?ac=OM.PW.PW003K20328T7073a
(attachments)
test_script.py (808 Bytes)
In 7.0, it fails because upper-case letters are not valid in option
names, so it interprets an argument of the form 'X=A a' as an answer
to the first option, i.e. equivalent to 'X=X=A a'.
I don't know why it would fail in 6.x.
