[GRASS-user] Problems with grass for OSX
Dear Jose,
when did your problem occur? After installation/updating or haphazardly?
I had a similar problem with the Python GUI but after I updated all frameworks it worked fine. In case you use the GRASS version from Kyngchaos can you update the GDAL complete framework, free type and cairo and report whether the error still occurs?
Regards
Ralf
Am 10.12.2011 um 05:20 schrieb grass-user-request@lists.osgeo.org:
Message: 3
Date: Fri, 9 Dec 2011 17:04:12 -0200
From: Jos? Carlos Guerrero Ant?nez <jcgantunez@gmail.com>
Subject: [GRASS-user] Problems with grass for OSX
To: grass-user@lists.osgeo.org
Message-ID:
<CAEO28jeO+PyOtLMWNn8bGnY3S6c-zAxWRwL2L97Y4iryJUMY0A@mail.gmail.com>
Content-Type: text/plain; charset=“iso-8859-1”
I can not boot properly grass and this is the message that appears in Terminal
window.
OSX 10.6.8
Thanks in advance,
torre-b-024:~ joseca_IMac$
‘/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh’; exit
Rebuilding Addon HTML manual pages index…
Rebuilding Addon menu…
Python 2.6.1 found.
WELCOME TO GRASS Version 6.4.1 2011
  1. Have at your side all available GRASS tutorials
  2. When working on your location, the following materials
    are extremely useful:
  • A topo map of your area
  • Current catalog of available computer maps
  1. Check the GRASS webpages for feedback mailinglists and more:
    http://www.grass-gis.org
    http://grass.osgeo.org
Hit RETURN to continue
Starting GRASS …
File
“/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py”, line
641, in OnSelectLocation
self.listOfLocations[self.lblocations.GetSelection()]))
File
590, in UpdateMapsets
self.listOfMapsets = utils.GetListOfMapsets(self.gisdbase, location)
File
“/Users/Shared/src/GRASS/grass-6.4.1-snow/dist.i386-apple-darwin10.7.0/etc/wxpython/gui_modules/utils.py”,
line 629, in GetListOfMapsets
File
line 651, in EncodeString
File
“/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/locale.py”,
line 459, in getdefaultlocale
return _parse_localename(localename)
File
line 391, in _parse_localename
raise ValueError, ‘unknown locale: %s’ % localename
ValueError: unknown locale: UTF-8
File
858, in
GRASSStartUp = StartUp(0)
File
“/Users/Shared/unix/wxpython-snow/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py”,
line 7981, in init
File
line 7555, in _BootstrapApp
File
843, in OnInit
StartUp.OnBrowse(None)
File
703, in OnBrowse
self.OnSetDatabase(event)
File
692, in OnSetDatabase
self.OnSelectLocation(None)
File
File
File
File
File
File
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue…
Dr. José Carlos Guerrero
Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio
(LDSGAT)
Instituto de Ecología y Ciencias Ambientales (IECA)
Facultad de Ciencias
Universidad de la República
Montevideo-URUGUAY
Hello again,
When I make double-click to open GRASS in the first terminal window show the following message,
Last login: Wed Dec 14 08:45:59 on console
torre-b-024:~ joseca_IMac$ ‘/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh’; exit
Python 2.6.1 found.
When I make RETURN, the message is “GRASS needs a directory in which to store its data. Create one now if you have not already done so. A popular choice is “grassdata”, located in your home directory.”
I do OK, and Choose a folder and then occurs as I mentioned in the previous mail.
This problem as I have working with an Imac10,1, Intel Core Duo, 3,06 GHz, RAM Memory 4 Gb. These The strangest thing for me I can do the program on another machine (MacBook Pro, ODX 10.6.8)
I did the installation and updated according to the procedure from Kyngchaos webpage. I have no doubt that there is some component that is in conflict but which?
Now, what can I do?
Many thanks for your help
2011/12/10 Ralf Schäfer <senator@ecotoxicology.de>
Dear Jose,
Regards
Ralf
Message: 3
Message-ID:
window.
OSX 10.6.8
Thanks in advance,
Python 2.6.1 found.
Starting GRASS …
File
File
File
File
File
File
File
858, in
File
line 7981, in init
File
File
843, in OnInit
File
703, in OnBrowse
File
File
File
File
File
File
File
(LDSGAT)
Montevideo-URUGUAY
Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio (LDSGAT)
Montevideo-URUGUAY
Maybe your shell language isn't set right? What do these return in a new Terminal window:
env | grep LANG
env | grep LC_
OS X automatically sets LANG, but there are others that are checked first: LC_ALL and LC_CTYPE. Python is expecting them to be in the form:
language.encoding
ie, the default US english is "en_US.UTF-8".
If any of those are just the encoding (the "UTF-8" in your error), then maybe you added something to your ~/.bash_profile to set them?
On Dec 14, 2011, at 8:14 AM, José Carlos Guerrero Antúnez wrote:
Hello again,
'/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
torre-b-024:~ joseca_IMac$ '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.6.1 found.
   1) Have at your side all available GRASS tutorials
   2) When working on your location, the following materials
      - A topo map of your area
      - Current catalog of available computer maps
   3) Check the GRASS webpages for feedback mailinglists and more:
When I make RETURN, the message is "GRASS needs a directory in which to store its data. Create one now if you have not already done so. A popular choice is "grassdata", located in your home directory."
Now, what can I do?
Dear Jose,
Regards
Ralf
Message: 3
Message-ID:
Content-Type: text/plain; charset="iso-8859-1"
window.
OSX 10.6.8
Thanks in advance,
Python 2.6.1 found.
Starting GRASS ...
File
"/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py", line
File
File
"/Users/Shared/src/GRASS/grass-6.4.1-snow/dist.i386-apple-darwin10.7.0/etc/wxpython/gui_modules/utils.py",
File
File
"/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/locale.py",
File
   raise ValueError, 'unknown locale: %s' % localename
File
858, in <module>
File
"/Users/Shared/unix/wxpython-snow/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py",
line 7981, in __init__
File
File
843, in OnInit
File
703, in OnBrowse
File
File
File
File
File
File
File
Hit RETURN to continue...
(LDSGAT)
Montevideo-URUGUAY
Montevideo-URUGUAY
grass-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
I did the return in a new Terminal window and
env | grep LANG
env | grep LC_
LC_CTYPE=UTF-8
So how I can make the change?
Many thanks again,
Jose Guerrero
El 14 de diciembre de 2011 12:44, William Kyngesburye <woklist@kyngchaos.com> escribió:
Maybe your shell language isn’t set right? What do these return in a new Terminal window:
env | grep LANG
env | grep LC_
language.encoding
ie, the default US english is “en_US.UTF-8”.
If any of those are just the encoding (the “UTF-8” in your error), then maybe you added something to your ~/.bash_profile to set them?
Hello again,
Python 2.6.1 found.
Now, what can I do?
Dear Jose,
Regards
Ralf
Message: 3
Message-ID:
window.
OSX 10.6.8
Thanks in advance,
Python 2.6.1 found.
Starting GRASS …
File
File
File
File
File
File
File
858, in
File
line 7981, in init
File
File
843, in OnInit
File
703, in OnBrowse
File
File
File
File
File
File
File
(LDSGAT)
Montevideo-URUGUAY
Montevideo-URUGUAY
William Kyngesburye <kyngchaosatkyngchaosdotcom>
Earth: “Mostly harmless”
  • revised entry in the HitchHiker’s Guide to the Galaxy
You need to find out where that is set. Most likely in your ~/.bash_profile. Then remove that setting.
And since your LANG is not set, you also need to check your Terminal preferences. In Settings:Advanced for your default setting, check the International "Set locale environment variables on startup" option.
On Dec 14, 2011, at 9:00 AM, José Carlos Guerrero Antúnez wrote:
env | grep LANG
env | grep LC_
LC_CTYPE=UTF-8
Many thanks again,
Jose Guerrero
env | grep LANG
env | grep LC_
language.encoding
> Hello again,
> Python 2.6.1 found.
> Now, what can I do?
> Dear Jose,
> Regards
> Ralf
>> Message: 3
>> Message-ID:
>> Hi,
>> window.
>> OSX 10.6.8
>> Thanks in advance,
>> Python 2.6.1 found.
>> Starting GRASS ...
>> File
>> File
>> File
>> File
>> File
>> File
>> File
>> 858, in <module>
>> File
>> File
>> File
>> 843, in OnInit
>> File
>> 703, in OnBrowse
>> File
>> File
>> File
>> File
>> File
>> File
>> File
>> (LDSGAT)
>> Montevideo-URUGUAY
> Montevideo-URUGUAY
"Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings. And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
How to remove that setting, this is the mesage when I write in Terminal window, I have all privileges as administrator.
~/.bash_profile
sh: /var/root/.bash_profile: No such file or directory
Thank you,
El 14 de diciembre de 2011 13:10, William Kyngesburye <woklist@kyngchaos.com> escribió:
And since your LANG is not set, you also need to check your Terminal preferences. In Settings:Advanced for your default setting, check the International “Set locale environment variables on startup” option.
env | grep LANG
env | grep LC_
LC_CTYPE=UTF-8
Many thanks again,
Jose Guerrero
env | grep LANG
env | grep LC_
language.encoding
Hello again,
Python 2.6.1 found.
Now, what can I do?
Dear Jose,
Regards
Ralf
Message: 3
Message-ID:
window.
OSX 10.6.8
Thanks in advance,
Python 2.6.1 found.
Starting GRASS …
File
File
File
File
File
File
File
858, in
File
line 7981, in init
File
File
843, in OnInit
File
703, in OnBrowse
File
File
File
File
File
File
File
(LDSGAT)
Montevideo-URUGUAY
Montevideo-URUGUAY
"Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings. And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence…
  • the wisdom of Tarzan
You need to edit it. But not in the root account home. Use pico or nano in the Terminal, or TextWrangler.app is also a good text editor for this (edit ~/.bash_profile).
On Dec 14, 2011, at 11:05 AM, José Carlos Guerrero Antúnez wrote:
~/.bash_profile
Thank you,
> Hi,
> env | grep LANG
> env | grep LC_
> LC_CTYPE=UTF-8
> Many thanks again,
> Jose Guerrero
> env | grep LANG
> env | grep LC_
> language.encoding
> > Hello again,
> > Python 2.6.1 found.
> > Now, what can I do?
> > Dear Jose,
> > Regards
> > Ralf
> >> Message: 3
> >> Message-ID:
> >> Hi,
> >> window.
> >> OSX 10.6.8
> >> Thanks in advance,
> >> Python 2.6.1 found.
> >> Starting GRASS ...
> >> File
> >> File
> >> File
> >> File
> >> File
> >> File
> >> File
> >> 858, in <module>
> >> File
> >> File
> >> File
> >> 843, in OnInit
> >> File
> >> 703, in OnBrowse
> >> File
> >> File
> >> File
> >> File
> >> File
> >> File
> >> File
> >> (LDSGAT)
> >> Montevideo-URUGUAY
> > Montevideo-URUGUAY
> > _______________________________________________
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
