Hello,
I'm having major problems with the Lidar tools. I've got a dataset with
5.5-7.0 points per m² and have run v.edgedetection on the original point
cloud containing all points with a the spline step parameters set to 0.6 and
the other parameters set as outlined in "Inverse calibration of lidar
filterimg parameters" by Brovelli & Lucca. Nonetheless, the edges detected
don't seem to have a whole lot to do with actual edges in the scene,
buildings look like they're completly ignored. Another fact is that I can't
see the data in nviz, it claims that there are no points in the region, even
though I've set the region settings to match the LiDAR data set.
More confusing, I can tell GRASS to show the points with random colors
according to their classes, but I can't see the classes themselves in the
attribute table, so I can't extract them thematically or control how they're
shown. If I build topology again for that classes, I can open the attribute
table, but it only has two fields: ID and Interp. Can't figure out what they
mean, and v.lidar.growing doesn't change the map at all. What's going on??
Thanks a bunch,
Daniel
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-with-lidar-tools-tp6418988p6418988.html
