Hello together !
I have problems with NVIZ Volume visualization !
Here I made an example generating a simple 3dgrid volume assuming subterranean data and the failing of visualizing it. I would really appreciate some help !
Here the short workflow:
#Generating three surfaces which will model the volume.
GRASS 6.2.2 (4326):~ > r.mapcalc dem.t=0
GRASS 6.2.2 (4326):~ > r.mapcalc dem.m=-10
GRASS 6.2.2 (4326):~ > r.mapcalc dem.b=-20
#My region settings
GRASS 6.2.2 (4326):~ > g.region -p3
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: a=6378137 es=0.006694379990141316
north: 24:56:24N
south: 12:54S
west: 75:52:12E
east: 114:17:24E
top: 0.00000000
bottom: -20.00000000
nsres: 0:59:44.842105
nsres3: 0:59:44.842105
ewres: 1:00:39.789474
ewres3: 1:00:39.789474
tbres: 1
rows: 38
rows3: 38
cols: 38
cols3: 38
depths: 20
cells: 1444
3dcells: 28880
#Generating the 3d grid volume
GRASS 6.2.2 (4326):~ > r.to.rast3 input=dem.b,dem.m,dem.t output=dem –o
#Visualizing it!
GRASS 6.2.2 (4326):~ > nviz volume=dem elevation=dem.t
When visualizing the 3dgrid volume dem, together with the raster surfaces, only outlines in form of a cube volume are drawn whenever navigating in space !!! else nothing is seen but the raster surfaces.
When adding a new constant value, for example -10, to the raster volume, an associated unique colored surface at the bottom of the cube is observable.
So, I´m not sure about what could be the problem or my mistake in the settings selection.
Furthermore I would like to know how to change g.region res3, respectivly tbres for latitude longitude locations, when I try to change res3<0:59:44.842105 or tbres my region get’s destroyed, definitely.
For what stands the default value 1 of tbres ?
Could somebody offer more information about vertical resolution specifications for latitude longitude locations.
That works : Slovakia3d can be visualised by adding new constant value for the raster volume.
Many thanks !
Suena
Gesendet von Yahoo! Mail.
Dem pfiffigeren Posteingang.
