I've emailed with Laura about r.terracost and she would be happy to have someone convert the make file to work with grass6.
Jerry
---- Original message ----
Date: Fri, 25 May 2007 17:54:06 +1200
Subject: Re: [GRASS-user] problems with r.cost
To: "Jonathan Greenberg" <greenberg@ucdavis.edu>
Cc: grassuser@grass.itc.it
Jonathan Greenberg wrote:
Hamish (and all): Paul is working with me on this project, and the
system we are running it on is a 64-bit debian system with plenty of
RAM/scratch space (and the version we are using is the 64-bit grass
release) -- why would memory problems be an issue? We tried lowering
the % memory but it doesn't seem to help...
does it work for a smaller region or coarser resolution? for example try
changing it from 3 to 30m res.
ie can you determine if is it a 64bit computational error or an out-of-
resources error? (does r.cost work for the spearfish DEM on your system?)
I can't answer why memory problems would be an issue, but that doesn't
mean they aren't! Large mem grass is still untested territory in many
places, maybe you have discovered something new.
Did r.terracost work? How does that compare to r.cost? (if it's good,
I'm thinking maybe Laura would allow us to merge it in CVS as a
companion to r.terraflow, or package as a GEM)
Or does that use GRASS 5 sites as starting/end points and need porting?
Hamish
grassuser mailing list
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
This would be a great asset to grass6 -- I know several people who would
directly benefit from this!
cheers,
dylan
Jerry
>From: Hamish <hamish_nospam@yahoo.com>
>Hamish
>_______________________________________________
Gerald Nelson
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
