I see.
There must be a couple people on the grass list who can look at it. If you
can, try and get in touch with the SOC people, as there is a project related
to cost surface analysis - they might be able to help.
dylan
On Friday 25 May 2007 14:13, Gerald Nelson wrote:
She didn't seem to be volunteering any of her students. She, and they, had
moved on. It was primarily a CS exercise for them. Sigh. Jerry---- Original message ----
>Date: Fri, 25 May 2007 13:39:46 -0700
>From: Dylan Beaudette <dylan.beaudette@gmail.com>
>Subject: Re: [GRASS-user] problems with r.cost
>To: Gerald Nelson <gnelson@uiuc.edu>
>Hmm. Good point. I am not really competent with Makefiles...
>Hopefully one of Laura's students can do it.
>cheers,
>dylan
>On Friday 25 May 2007 09:20, Gerald Nelson wrote:
>> How's your C? Mine doesn't exist. I looked at the gmake file (which is
>> what was used for grass 5) and a make file for the r.cost module in
>> grass 6). I couldn't figure out what needed to be changed.
>> Regards, Jerry
>> >Date: Fri, 25 May 2007 09:19:23 -0700
>> >To: grassuser@grass.itc.it
>> >Cc: Gerald Nelson <gnelson@uiuc.edu>, Hamish <hamish_nospam@yahoo.com>,
>> > Jonathan Greenberg <greenberg@ucdavis.edu>
>> >This would be a great asset to grass6 -- I know several people who
>> > would directly benefit from this!
>> >cheers,
>> >dylan
>> >On Friday 25 May 2007 05:54, Gerald Nelson wrote:
>> >> I've emailed with Laura about r.terracost and she would be happy to
>> >> have someone convert the make file to work with grass6.
>> >> Jerry
>> >> >Date: Fri, 25 May 2007 17:54:06 +1200
>> >> >From: Hamish <hamish_nospam@yahoo.com>
>> >> >To: "Jonathan Greenberg" <greenberg@ucdavis.edu>
>> >> >Cc: grassuser@grass.itc.it
>> >> >Jonathan Greenberg wrote:
>> >> >> Hamish (and all): Paul is working with me on this project, and the
>> >> >> system we are running it on is a 64-bit debian system with plenty
>> >> >> of RAM/scratch space (and the version we are using is the 64-bit
>> >> >> grass release) -- why would memory problems be an issue? We tried
>> >> >> lowering the % memory but it doesn't seem to help...
>> >> >does it work for a smaller region or coarser resolution? for example
>> >> > try changing it from 3 to 30m res.
>> >> >ie can you determine if is it a 64bit computational error or an
>> >> > out-of- resources error? (does r.cost work for the spearfish DEM on
>> >> > your system?)
>> >> >I can't answer why memory problems would be an issue, but that
>> >> > doesn't mean they aren't! Large mem grass is still untested
>> >> > territory in many places, maybe you have discovered something new.
>> >> >Did r.terracost work? How does that compare to r.cost? (if it's
>> >> > good, I'm thinking maybe Laura would allow us to merge it in CVS as
>> >> > a companion to r.terraflow, or package as a GEM)
>> >> >Or does that use GRASS 5 sites as starting/end points and need
>> >> > porting?
>> >> >Hamish
>> >> >_______________________________________________
>> >> >grassuser mailing list
>> >> >http://grass.itc.it/mailman/listinfo/grassuser
>> >> Gerald Nelson
>> >> Professor, Dept. of Agricultural and Consumer Economics
>> >> University of Illinois, Urbana-Champaign
>> >> office: 217-333-6465
>> >> cell: 217-390-7888
>> >> 315 Mumford Hall
>> >> 1301 W. Gregory
>> >> Urbana, IL 61801
>> >Dylan Beaudette
>> >Soils and Biogeochemistry Graduate Group
>> >University of California at Davis
>> >530.754.7341
>> Gerald Nelson
>> cell: 217-390-7888
>> 315 Mumford Hall
>> 1301 W. Gregory
>> Urbana, IL 61801
>Dylan Beaudette
>530.754.7341Gerald Nelson
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
Dylan Beaudette
530.754.7341
