[GRASS-user] problems with r.neighborhoodmatrix
I have this error with r.neighborhoodmatrix
could you help?
thanks
File
“/home/zuliagr/.grass7/addons/scripts/r.neighborhoodmatrix”,
line 190, in
main()
File
line 150, in main
for line in heapq.merge(*[decorated_file(f, keyfunc) for
f in files]):
File “/usr/lib/python2.7/heapq.py”, line 376, in merge
h_append([next(), itnum, next])
File
line 96, in decorated_file
yield (key(line), line)
File
line 92, in keyfunc
return [int(x) for x in s.split(separator)[:2]]
ValueError: invalid literal for int() with base 10:
‘0-0.003922’
Hello Gra,
could you help?
thanks
File
"/home/zuliagr/.grass7/addons/scripts/r.neighborhoodmatrix",
line 190, in <module>
main()
File
line 150, in main
f in files]):
File "/usr/lib/python2.7/heapq.py", line 376, in merge
File
File
line 92, in keyfunc
'0-0.003922'
The value 0-0.003922 seems to indicate that you are not using an integer map. Calculating a neighborhood matrix only makes sense for clearly defined objects and this implies an identification with integer ids (such as the ones coming out of r.clump or i.segment).
To make sure this is the problem, please send us the r.info output on your input map.
I just committed a revised version of the addon which checks the map type and gives a fatal error if it is not the expected integer type. Reinstall the extension and tell us what you get.
BTW, you sent me a private mail [please don't do that: mails should always go to the list] concerning an error in r.object.spatialautocor where you also have an error in r.neighborhoodmatrix, using the following command:
r.object.spatialautocor ob=maskAT001L2_50 var=RPnAT001L2@in_data method=moran
maskAT001L2_50 = raster map value 1
RPnAT001L2 = my variable
I suspect the reason for the error is similar, but to make sure, please send the output of
r.info maskAT001L2_50
Moritz
Dear Grazia,
Once again: Please refrain from sending private mails.
I am happy that you found a solution, although I don't really understand how: your "object" map has only one single object. r.object.autocorrelation compares objects with their neighbors, as identified with r.neighborhoodmatrix, to calculate spatial autocorrelation. As you only have one object, there are no neighbors. So, you won't have any neighborhood matrix, and so no object-based spatial autocorrelation.
Moritz
On 26/02/18 16:48, Gra wrote:
Hi Moritz
just to tell you that I got it!
I worked during the week end and I made it work (my error was on the first input)
Thanks a lot for your help
Grazia
2018-02-23 16:19 GMT+01:00 Gra <graziaz@gmail.com <mailto:graziaz@gmail.com>>:
    Hi
    here is the result of r.info <http://r.info> of my map
    r.info <http://r.info> map=maskAT001L2_50@in_data
      | Map: maskAT001L2_50@in_data Date: Tue Jan 23
    16:46:56 2018 |
      | Mapset: in_data Login of Creator:
    zuliagr |
      | DataBase: /DATA/zuliagr/grassdata |
      | Title: Categories |
      | Timestamp: none |
      | Type of Map: raster Number of Categories: 0 |
      | Data Type: CELL |
      | Rows: 2617 |
      | Columns: 2381 |
      | Total Cells: 6231077 |
      | Projection: ETRS89 / LAEA Europe |
      | N: 2879700 S: 2748850 Res: 50 |
      | E: 4854650 W: 4735600 Res: 50 |
      | Range of data: min = 1 max = 1 |
      | Data Source: |
      | Vector Map: FUA_AT001L2 |
      | Original scale from vector map: 1:1 |
      | Data Description: |
      | generated by v.to.rast |
      | Comments: |
      | v.to.rast --overwrite input="FUA_AT001L2" layer="1"
    type="point,line\ |
      | ,area" output="maskAT001L2_50" use="attr"
    attribute_column="ras" val\ |
      | ue=1 memory=300
    practically this is the surface of a city (I am working 700 cities
    in Europe)
    I need to compute the moran stat for several indicators to see if
    the are dispersed or clumped.
    I attach an example of inputs (result is the indicator).
    can I use your module?
    if yes can you explain me how to organise the data?
    if you prefer I can move the conversation to the user list.
    Many thanks for your help
    Grazia
    PS I could not download the new version yet, I work under a proxy
    and the downloading is a bit tricky, I will do that on Monday.
    2018-02-22 11:34 GMT+01:00 Moritz Lennert
    <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>>:
        Hello Gra,
            could you help?
            thanks
              File
              main()
              File
            line 150, in main
            f in files]):
              File
              File
            line 92, in keyfunc
            '0-0.003922'
        i.segment).
        <http://r.info> output on your input map.
        r.info <http://r.info> maskAT001L2_50
        Moritz
