[GRASS-user] problems with v.edit
----Messaggio originale----
Da: landa.martin@gmail.com
Data: 20/01/2009 19.20
A: "chiaraercoli@tiscali.it"<chiaraercoli@tiscali.it>
Cc: <grass-user@lists.osgeo.org>
Ogg: Re: [GRASS-user] problems with v.edit
2009/1/20 chiaraercoli@tiscali.it <chiaraercoli@tiscali.it>:
I have a problem with v-edit.
I have to break a vector line
into two parts near a point. I gave this command:
v.edit map=ret_125
layer=1 type=line tool=break thresh=$ris_edit coords=$x,$y snap=no
where " $ris_edit " depends on the resolution of the DEM raster
map,
"$x" and "$y" are the coordinates of the point.
are you sure that threshold value is enough to select vector feature
which you want to break?
v.edit map=ret_125 tool=select thresh=$ris_edit coords=$x,$y
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
I send you the line, ret_125, and the point, punto_minimo.
Thanks for all,
  Chiara .
   _______________________________________________________________
Attiva Tiscali Tutto Incluso: telefoni e navighi senza limiti A SOLI €10 AL MESE FINO ALL?ESTATE. Attiva entro il 22/01/09!
http://abbonati.tiscali.it/promo/tuttoincluso/
(attachments)
punto_minimo@thresh12000.shp (128 Bytes)
ret_125@thresh12000.prj (397 Bytes)
ret_125@thresh12000.dbf (189 Bytes)
ret_125@thresh12000.shx (108 Bytes)
ret_125@thresh12000.shp (2.23 KB)
punto_minimo@thresh12000.dbf (232 Bytes)
punto_minimo@thresh12000.shx (108 Bytes)
