Hi all.
Compiled and installed Grass 6.5 from source on a 64x Ubuntu 9.04 machine. It seemed to me it worked fine but when I tried to import the curvespear shape file (following the step by step tutorial http://www.ing.unitn.it/~grass/docs/tutorial_62/index.html ) by v.in.ogr function, the procedure didn't go on. In the output window:
Layer: curvespear
Importing map 1755 features...
and nothing else.
The imported file is in the right place but with nearly no feature inside.
I'v been looking for a tip in the user mailing list archive but Rafael Moraes suggestion doesn't help. Added http://les-ejk.cz/ubuntu repository to source list and reinstalled gdal... but nothing happend.
The same with Grass 6.2.3. (Maybe I made some newbe mistake in updating gdal).
Any suggestion?
Thank you.
Ferro
P.S
Hi all.
function, the procedure didn’t go on. In the output window:
Layer: curvespear
Importing map 1755 features…
and nothing else.
I’v been looking for a tip in the user mailing list archive but Rafael
Moraes suggestion doesn’t help. Added http://les-ejk.cz/ubuntu
repository to source list and reinstalled gdal… but nothing happend.
updating gdal).
Any suggestion?
Thank you.
Ferro
P.S
I have the same problem when I tried to import the shapefile with v.in.org
I’m working with GRASS 6.4.0svn on a 64x Ubuntu 9.04
In the terminal give this errors
GRASS 6.4.0svn (Prueba_location):~ > *** buffer overflow detected ***: v.in.ogr terminated
======= Backtrace: =========
/lib/libc.so.6(__fortify_fail+0x37)[0x7f95d00bc2c7]
/lib/libc.so.6[0x7f95d00ba170]
/lib/libc.so.6[0x7f95d00b97ab]
/lib/libc.so.6(__snprintf_chk+0x7b)[0x7f95d00b967b]
/usr/lib/libgdal1.5.0.so.1(_ZN10OGRFeature16GetFieldAsStringEi+0x346)[0x7f95d0de2296]
v.in.ogr(main+0x2284)[0x406b50]
/lib/libc.so.6(__libc_start_main+0xe6)[0x7f95cffdb5a6]
v.in.ogr[0x403969]
Some advice?
Thaks
John Ortiz
Disfruta antes que nadie del nuevo Windows Live Messenger
Jhon Ortiz:
v.in.org
I'm working with GRASS 6.4.0svn on a 64x Ubuntu 9.04
Some advice?
Hi John.
This is a known "situation". Look at [1][2][3] and I am convinced that
you'll resolve the conflict.
( Maybe we should add a wiki-page with these kind of errors? )
Kind regards, Nikos
[1]
http://n2.nabble.com/Buffer-overflow-v.in.ogr-on-GRASS-6.4-RC2-tc2151192.html#a2151192
[2] http://n2.nabble.com/gdal%2C-v.in.ogr%
2C-Ubuntu-intrepid-tc1886320.html#a1886323
[3]
http://n2.nabble.com/GRASS-6.4-and-Ubuntu-Intrepid-tc1885119.html#a1885119
Hope John solved his issue but it's quite different from mine.
I guess the problem I'm facing with v.in.ogr function have been solved by Jachym Cepicky ( http://n2.nabble.com/grass-gdal-ubuntu-issue-solved-(-)-td2352498.html ), whose unofficial repository hold some updated packages that seems to work very well... Unfortunately I'm working on a 64bit pc with Ubuntu 9.04 and no package for this configuration is available there.
I compiled a Grass 6.5 from source but really don't know on how to compile a more recent version of gdal and even don't know exactly wich libraries have to be updated.
Some useful suggestion on what to do to make v.in.ogr work correctly with shp files?
Thank you in advance.
Ferro
Jhon Ortiz ha scritto:
Hi all.
Layer: curvespear
and nothing else.
Any suggestion?
Thank you.
Ferro
P.S
I have the same problem when I tried to import the shapefile with v.in.org I'm working with GRASS 6.4.0svn on a 64x Ubuntu 9.04
v.in.ogr[0x403969]
Some advice?
Thaks
John Ortiz
_________________________________________________________________
Llévate Messenger en el móvil a todas partes ¡Conéctate!
http://www.microsoft.com/spain/windowsmobile/messenger/default.mspx
grass-user mailing list
grass-user@lists.osgeo.org
