Hi Roberto,
I did a cvs update on my linux machine and the seg fault bug is fixed. Cheers!
I've also done a bunch more experimenting on both my linux machine and my mac and found out that the error that I reported is not specific to the mac. It occurs on my SUSE 10.1 machine as well. At first I thought it was related to the size of my vector files, but after severe decimation of one of the input files I realized that it was related to the region bounds for the mapset. More specifically, it seems to be related to the relationship between the size of the region and the spline interpolation step value.
In a nutshell, if the region dimensions are more than 250 times the spline interpolation step value in either axis then v.outlier & v.lidar.edgedetection (and probably v.lidar.correction, but havn't tested) will fail with the driver error below. So for the command;
#Region size of 1000X2500m
GRASS 6.2.0 (Mudflats):~ > g.region n=5276000 s=5275000 e=581500 w=579000 ewres=1 nsres=1
GRASS 6.2.0 (Mudflats):~ > v.outlier input=pslc2k output=clean outlier=outlier
v.outlier complete
SUCCESS
#Region size of 1000x2501m
GRASS 6.2.0 (Mudflats):~ > g.region n=5276000 s=5275000 e=581501 w=579000 ewres=1 nsres=1
GRASS 6.2.0 (Mudflats):~ > v.outlier input=pslc2k output=clean outlier=outlier --o
DBMI-SQLite driver error:
Error in sqlite3_prepare():
no such table: Auxiliar_outlier_table
ERROR: Impossible to write in the database
FAILURE
As does;
#Region size of 100X2501m
GRASS 6.2.0 (Mudflats):~ > g.region n=5275100 s=5275000 e=581501 w=579000 ewres=1 nsres=1
FAILURE
This is true for both my Mac and my Linux machine (both 32bit). Now that I know how to trigger it, it's pretty easy to work around, but I just though I'd let you know in case it gives you any ideas as to what may be causing it.
On a side note, I noticed that the parameter name for the spline interpolation step is different for each program that uses it. Ie, for the north-south interpolation step in v.outlier it is "son", in v.surf.spline it is "sin", in v.lidar.edgedetection it is "sen" and "scn" for v.lidar.correction. Is there some difference to it's use in each of these commands? Otherwise, it might be better if they all possessed the same name. Just a though.
Anyways, I hope this info helps.
Mike
On 13-Nov-06, at 3:52 AM, Roberto Antolin wrote:
Hi Mike and all,
I resolved the v.outlier bug successfully(?) and now it is not necessary setting the "qgis=" parameter any more. Only if you want, of course
The dbf driver error is very bizarre. This morning I made some tests with both dbf driver and db and I had the same problem. I was trying to understand it when the computer shutdown because of a non related problem. The point is that after the restart, I did the same tests and everything run ok.
It's a pity that I haven't got a mac to make some tests, so I'm not able to say you anything. Anyway, I'll try to understand better which is the real problem with dbf. I'll let you know if I find out something
Michael Perdue ha scritto:
Hi Roberto,
Thanks for the info. I'm still pretty new to macintosh and so far haven't had much luck (read lazy) at setting up the environment for building binaries myself. I did run it with the qgis option however, and although it didn't complain about a "bus error", it did shut down with the same error reported by v.lidar.edgedetection;
DBMI-DBF driver error:
Table 'Auxiliar_edge_table' doesn't exist.
Error in db_execute_immediate()
So, it seems that what ever is causing the error is specific to mac and may be common to all the v.lidar.* programs. I have a linux workstation in the office and I did a cvs update earlier today. The binaries were building when I left so in the morning I'll run everything through it and then move the files over to my mac and see if the issue also affects v.lidar.* and v.surf.bspline. I'll let you know what I find out. Let me know if there is anything I can do to be of assistance.
Cheers and thanks again!
Mike
Roberto Antolín Sánchez
Politecnico di Milano – Polo Regionale di Como
(Laboratorio di Geomatica V2.8)
Via Valleggio, 11 – 22100 Como, Italy
tel: +39 031 332 7533 || fax: +39 031 332 7519 email: roberto.antolin@polimi.it
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection aroundhttp://mail.yahoo.com
