[GRASS-user] Problems with v.to.db after breaking with v.edit
Does this helps you?
v.category input=map_of_vedit output=map2 option=add layer=2
v.db.addtable map=map2 layer=2 table=table2
In that way you preserve original information in layer1, and new categories in layer2
Hopefully that will be useful. Maybe someone has a better idea.
Daniel
Dear list
I break a number of features in a vector map into two pieces using
v.edit, tool=break and specific coordinates. This results in two parts
with identical attributes after breaking (which is what I want) but also
the cat is identical.
I think, this is the reason why I get exactly the same length for the
two parts when calculating it using v.to.db, tool=length. Likewise, the
end coordinates cannot be computed as there is more than one element for
some categories.
How can I update the category to unique values for each feature?
Thanks for any suggestions,
Mira
Hello
Thanks for the advice.
The first step suggested does produce a new vector map with the old information in layer 1 and new categories in layer 2 (nothing else).
However, I do not understand the 2nd step. Do you really mean to connect table2 (I guess that is the one belonging to map2) to map2? It is already connected. Connecting it to map_of_vedit also does not work (i.e. nothing happens):
0 categories read from vector map (layer 2)
7759 records selected from table (layer 2)
0 records updated/inserted (layer 2)
Current attribute table links:
Maybe I should give a bit more information:
I have a stream network with a few junctions with more than two inflows. For the things I want to do afterwards, only two inflows are allowed. Therefore, I cut the outflow segment close to the junction and reconnect one of the inflows to the cut point to create a new junction with only tow inflows (the moved one and the short bit of the old outflow). Now I need to correct the relations of the streams (originally output of r.stream.order with columns stream, next, prev_str01, prev_str02,...). To this end, I want to change the stream id of the new shorter bit. To do this I have to calculate the lengths of the pieces, which seems not to work properly because the two pieces of the cut segment have the same cat.
Has anybody another idea?
Mira
Daniel
>Dear list
>some categories.
>Mira
Dr. Mira Kattwinkel
Quantitative Landscape Ecology
Institute for Environmental Sciences
University of Koblenz-Landau
Fortstraße 7
76829 Landau
Germany
Phone: + 49 6341 280-31553
Office: Building I, Room 2.02
