[GRASS-user] Problems with v.to.db and v.db.addcol
Under my Windows GRASS GIS the commands v.to.db and v.db.addcol did not work properly, when I wanted to calculate the areas of polygons. There were error meaaages that it could not poen or execute the dbase files. Does anybody how to overcome this problem ?
Best regards
Niels
Dr. Niels Thevs
Chair of Geobotany and Landscape Ecology
Institute of Botany and Landscape Ecology
Greifswald University
Grimmer Strasse 88
17487 Greifswald
Germany
Tel.: +49-3834-86-4137
Fax: +49-3834-86-4114
Could you please post the precise error message?
Thanks
Best regards
Niels
Dr. Niels Thevs
Grimmer Strasse 88
17487 Greifswald
Germany
Markus Neteler
Fondazione Mach - Centre for Alpine Ecology
38100 Viote del Monte Bondone (Trento), Italy
neteler AT cealp.it http://www.cealp.it/
I tried the v.to.db (Windows-Grass) again. Today no error message came out. But, with the default settings these messages came out:
v.to.db map=training_area_2_x_unsupervised_class_50@PERMANENT type=point,line,boundary,centroid layer=1 qlayer=1 option=area units=hectares column=b_label
Updating database...
5104 categories read from map
5104 records selected from table
5104 categories read from map exist in selection from table
0 categories read from map don't exist in selection from table
5104 records updated/inserted
0 update/insert errors
Then, I changed type to area:
v.to.db map=training_area_2_x_unsupervised_class_50@PERMANENT type=area layer=1 qlayer=1 option=area units=hectares column=b_label
ERROR: value <area> out of range for parameter <type>
        Legal range: point,line,boundary,centroid
Best regards
Niels
Thanks
Best regards
Niels
Dr. Niels Thevs
Grimmer Strasse 88
17487 Greifswald
Germany
Dr. Niels Thevs
Grimmer Strasse 88
17487 Greifswald
Germany
Yes, because "area" isn't supported (use boundary instead).
Best regards
