I am trying to use GRASS in Windows VISTA and I have some problems. I get to open but after select Location and mapsets and push ENTER GRASS y get "“Error in startup script” y dentro "cant read “pjr(units)”: no such variable while executin “set mapunitis…”
Somebody knows what could i do?
Ibon
On Wed, Mar 17, 2010 at 11:41 PM, Ibon Tamayo <ibontama@gmail.com> wrote:
""Error in startup script" y dentro "cant read "pjr(units)": no such
variable while executin "set mapunitis...."
This sounds like a broken GDAL or PROJ installation.
Which GRASS version do you use (where di you get it)?
