[GRASS-user] [Process ended with error code -1073741515]
Module import into python script is working fine. However, when I tried to print out the g.region with
gscript.run_command(‘g.region’,raster=‘nep_drain’,overwrite=True). It throws the following error.
Process ended with non-zero return code -1073741515
Any words would be appreciated.
Best,
(attachments)
Ang Dawa Sherpa
gscript.run_command('g.region',raster='nep_drain',overwrite=True). It
*Best,*
*Ang Dawa Sherpa*
grass-user mailing list
grass-user@.osgeo
<http://osgeo-org.1560.x6.nabble.com/attachment/5313360/0/xenia_error.png>
have a look in this thread:
https://lists.osgeo.org/pipermail/grass-user/2016-August/074634.html
grass.exceptions.CalledModuleError: Module run None ['g.gisenv', '-n'] ended
with error
Process ended with non-zero return code -1073741515. See errors in the
(error) output.
and here
http://stackoverflow.com/questions/1081276/where-can-i-find-a-list-of-all-windows-error-codes
to find the meaning of the error code in
https://msdn.microsoft.com/de-de/library/windows/desktop/ms681381(v=vs.85).aspx
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Process-ended-with-error-code-1073741515-tp5313360p5313370.html
some additional checks you may do:
- check if there are interfering/conflicting multiple python installations
on your system
- check if there are interfering/conflicting multiple gdal installations on
your system
- check if "download and install MS runtime binaries" during standalone
winGRASS installation procedure is activated.
this error seems to come from the underlying operating system.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Process-ended-with-error-code-1073741515-tp5313360p5313408.html
