[GRASS-user] Projection 4 String from metadata file (help)
Can anyone help me convert this to a projection for proj 4
<geogcsn Sync="TRUE">GCS_North_American_1983</geogcsn>
<projcsn
Sync="TRUE">NAD_1983_StatePlane_North_Carolina_FIPS_3200_Feet</projcsn>
</cordsysn>
<planar>
<mapproj>
<mapprojn Sync="TRUE">Lambert Conformal Conic</mapprojn>
<lambertc>
<stdparll Sync="TRUE">34.333333</stdparll>
<stdparll Sync="TRUE">36.166667</stdparll>
<longcm Sync="TRUE">-79.000000</longcm>
<latprjo Sync="TRUE">33.750000</latprjo>
<feast Sync="TRUE">2000000.002617</feast>
<fnorth Sync="TRUE">0.000000</fnorth>
</lambertc>
</mapproj>
<planci>
<plance Sync="TRUE">coordinate pair</plance>
<plandu Sync="TRUE">survey feet</plandu>
<coordrep>
<absres Sync="TRUE">0.000000</absres>
<ordres Sync="TRUE">0.000000</ordres>
</coordrep>
</planci>
</planar>
<geodetic>
<horizdn Sync="TRUE">North American Datum of 1983</horizdn>
<ellips Sync="TRUE">Geodetic Reference System 80</ellips>
<semiaxis Sync="TRUE">6378137.000000</semiaxis>
<denflat Sync="TRUE">298.257222</denflat>
</geodetic>
this could help:
  http://trac.osgeo.org/proj/wiki/GenParms
see also the proj4 documentation for your projection type which
discusses parameters used for by that projection.
Hamish
<projcsn
</cordsysn>
Does this look right?
http://www.spatialreference.org/ref/esri/102719/
If so, then the proj4 string is here:
http://www.spatialreference.org/ref/esri/102719/proj4/
for those interested the solution to my problem was that the metadata
was reporting in ft. and the proj 4 string is in meters. I wish Jimi
Carter had gotten his way. It would sure make my life easier.
for what its worth,
Stephen Sefick
> <projcsn
> </cordsysn>
