It took a while today for me to figure out where I went off the rails
importing a text file in Lat/Lon coordinates to Nevada East State Plane
Coordinate System, NAD 83, US Survey Feet (epsg:3421) using cs2cs. Still,
I've become confused because of the apparent switch in projection coordinate
sequence. Let me explain.
with the latitude first and the longitude second. What continues to throw me
is that the output apparently has the longitude (easting) first and the
latitude (northing) second:
543495.65 28676372.70
I confirmed this by using a Web page that does the conversions:
Latitude 41.42188333
Longitude 115.99418333
Calculated Values - based on Degrees Lat Long to seven decimal places.
Position Type Lat Lon
Degrees Lat Long 41.4218833°, -115.9941833°
Degrees Minutes 41°25.31300', -115°59.65100'
Degrees Minutes Seconds 41°25'18.7800", -115°59'39.0600"
State Plane X Y (Meters) 2701 165657.806mE 8740575.881mN
X Y (US Survey Feet) 2701 543495.651ftUSE 28676372.703ftUSN
X Y (International Feet) 2701 543496.738ftE 28676430.056ftN
State Plane Coordinate System, NAD 83, US Survey Feet
(epsg:3421) using cs2cs. Still, I've become confused because
n.b. lat,lon is y,x; note also the use of the +proj=latlong
alias instead of the true +proj=longlat setting, that doesn't
change the order but can help you see what's being done clearer;
and finally if you look at the option description in the cs2cs
man page -r only swaps the expected input order.
What continues to throw me is that the output apparently has
the longitude (easting) first and the latitude (northing)
second:
(x,y)
Why this change in coordinate order?
it's working as designed. If you want to reverse the order of
the output for some reason you need to use cs2cs's -s flag too.
