[GRASS-user] Projection of dataset does not appear to match the current location!!!
Hi!!
i am Trying to display one raster image kept on my harddisk,
I have kept spearfish60 on /usr/local/grassdata so I set Location : spearfish60
I have made one user user1 then i set Mapset: user1…
then i start grass ,
the n throu command
r.in.gdal -e in=nf42.tif out=tm
then i am getting the error,.,
I have tried the same thru GIS manager,
file->import->Raster->multiple formats using gdal…
I want to know where i am doing wrong…
Thanks in Advance
Thanks & Regards
Kunal Malik
09871147561
spearfish60
I have made one user user1 then i set Mapset: user1..
the n throu command
file->import->Raster->multiple formats using gdal..
I want to know where i am doing wrong..
You need to create a location whose projection matches the data you
wish to import.
Try using g.proj with the -c flag and the location= and georef=
options to create a new location based upon the projection information
in the file.
You should then be able to import the file into that location with
r.in.gdal. If desired, you can then re-project it to another location
with r.proj.
HI !!
If i don’t know the Projection Information of the File to be Imported,could i import the raster/vector file available…
i am Trying to display one raster image kept on my harddisk. I have kept spearfish60 on /usr/local/grassdata
so I set Location . spearfish60
the n throu command
spearfish60
the n throu command
wish to import.
in the file.
with r.proj.
Thanks & Regards
Kunal Malik
09871147561
On Wednesday 20 February 2008 08:33:05 Kunal Malik wrote:
HI !!
If i don't know the Projection Information of the File to be Imported,could
i import the raster/vector file available..
the n throu command
> > spearfish60
> > the n throu command
> wish to import.
> in the file.
> with r.proj.
If I understand you correctly, you are trying to find out the projection of
your raster file. You can use gdalinfo (outside of GRASS) to do that. With
the information from gdalinfo you can create a new location and import your
raster.
Greetings Frank
Kunal Malik píše v St 20. 02. 2008 v 13:03 +0530:
HI !!
Imported,could i import the raster/vector file available..
why didn't you just create new location ?
could I ask you, how "you did" the user1 ?
the n throu command
location!!!
if your data are not from spearfish60 region and with the same map
projection, then they should not be imported to the spearfish60
location. you should better create new location with map projection,
that corresponds with the projection of your map.
jachym
        Kunal Malik wrote:
        > i am Trying to display one raster image kept on my
        harddisk,
        > I have kept spearfish60 on /usr/local/grassdata so I set
        > spearfish60
        > I have made one user user1 then i set Mapset: user1..
        > then i start grass ,
        > the n throu command
        > r.in.gdal -e in=nf42.tif out=tm
        > then i am getting the error,.,
        > Projection of dataset does not appear to match the current
        location!!!
        > I have tried the same thru GIS manager,
        > file->import->Raster->multiple formats using gdal..
        > I want to know where i am doing wrong..
        data you
        wish to import.
        georef=
        information
        in the file.
        with
        location
        with r.proj.
Thanks & Regards
Kunal Malik
09871147561
grass-user mailing list
grass-user@lists.osgeo.org
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
The "Projection of dataset does not appear to match the current
location" error can only occur if the file is georeferenced. If it
isn't, r.in.gdal will just assume that it matches the projection of
the current location.
As Frank mentions, you can use gdalinfo to obtain the georeferencing
information.
And you can use "r.in.gdal location=" or "g.proj -c location=" to
create a new location with the correct projection based upon what's in
the file.
If a file isn't georeferenced and you don't have that information
available, you can import the file into an location with an X/Y
projection, although you will lose the ability to perform operations
which require projection information (e.g. reprojection).
More generally, if you have some data but don't know what part of the
planet that data refers to, you don't really have any data. It's like
knowing that the answer is 42 without knowing what the question is.
HI !!
the n throu command
spearfish60
the n throu command
wish to import.
in the file.
with r.proj.
If I understand you correctly, you are trying to find out the projection of your raster file. You can use gdalinfo (outside of GRASS) to do that. With the information from gdalinfo you can create a new location and import your raster.
Greetings Frank
Frank,
gdalinfo is a nice tool, thanks for the hint. Do you know if there is a similar tool for *.hgt-files (srtm)
cheers
Philipp
Hi!
Thanks for ur support.
As u have said ,i got the georefercing information using gdalinfo.
It give following output
Driver: GTiff/GeoTIFF
Size is 5177, 3450
Coordinate System is:
GEOGCS[" Unable to match Ellipsoid (Datum) to a GeographicTypeGeoKey value Ellipsoid = Modified Everest Datum = Modified Everest",
DATUM[“unknown”,
SPHEROID[“unnamed”,6377304.063,300.8017000971244]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433]]
Origin = (65.999420352116971,24.000579647883026)
Pixel Size = (0.001159295766052,-0.001159295766052)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=ERDAS IMAGINE
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 65.9994204, 24.0005796) ( 65d59’57.91"E, 24d 0’2.09"N)
Lower Left ( 65.9994204, 20.0010093) ( 65d59’57.91"E, 20d 0’3.63"N)
Upper Right ( 72.0010945, 24.0005796) ( 72d 0’3.94"E, 24d 0’2.09"N)
Lower Right ( 72.0010945, 20.0010093) ( 72d 0’3.94"E, 20d 0’3.63"N)
Center ( 69.0002574, 22.0007945) ( 69d 0’0.93"E, 22d 0’2.86"N)
Band 1 Block=64x64 Type=Byte, ColorInterp=Red
Metadata:
LAYER_TYPE=athematic
Band 2 Block=64x64 Type=Byte, ColorInterp=Green
Metadata:
Band 3 Block=64x64 Type=Byte, ColorInterp=Blue
Metadata:
and then i tried to import the tif file .
r.in.gdal -e in=nf42_geo.tif out=tm
WARNING: Datum ‘unknown’ not recognised by GRASS and no parameters found.
Datum transformation will not be possible using this projection
information.
Projection of input dataset and current location appear to match.
Proceeding with import…
100%
CREATING SUPPORT FILES FOR tm.red
SETTING GREY COLOR TABLE FOR tm.red (8bit, full range)
100%
CREATING SUPPORT FILES FOR tm.green
SETTING GREY COLOR TABLE FOR tm.green (8bit, full range)
100%
CREATING SUPPORT FILES FOR tm.blue
SETTING GREY COLOR TABLE FOR tm.blue (8bit, full range)
r.in.gdal complete.
now i am trying to display the imported file…
i got the error
g.region rast=tm
ERROR: raster map not found.
Please tell how could i display it.
Thanks in Advance
The “Projection of dataset does not appear to match the current
location” error can only occur if the file is georeferenced. If it
isn’t, r.in.gdal will just assume that it matches the projection of
information.
And you can use “r.in.gdal location=” or “g.proj -c location=” to
create a new location with the correct projection based upon what’s in
the file.
If a file isn’t georeferenced and you don’t have that information
More generally, if you have some data but don’t know what part of the
planet that data refers to, you don’t really have any data. It’s like
Thanks & Regards
Kunal Malik
09871147561
