Rich Shepard wrote:
On Wed, 17 Feb 2010, Markus Neteler wrote:
I think that a change of the base unit of a location requires a new
location and reprojection of the data. I may be wrong, though.Markus/Hamish:
I'm missing something critical here.
I defined a new location (called oregonM) with the following projection
information and units:PROJ_INFO:
name: Lambert Conformal Conic
proj: lcc
datum: nad83
ellps: grs80
lat_1: 43
lat_2: 45.5
lat_0: 41.45
lon_0: -120.5
x_0: 400000
y_0: 0
no_defs: defined
nadgrids: WOPROJ_UNITS:
unit: meter
units: meters
meters: 1Using the wxPython GUI I import the source DEM specifying hdr.adf as the
ARC/GRID source. On the options tab I check "override projection information
and use location's projection" because that file has the units in feet:[rshepard@salmo /usr4/Oregon]$ less dem10-nw/prj.adf
Projection LAMBERT Datum NAD83 Zunits NO Units 3.2808400000 Spheroid GRS1980 Xshift 0.0000000000 Yshift 0.0000000000 Parameters
43 0 0.000 /* 1st standard parallel
45 30 0.000 /* 2nd standard parallel -120 30 0.000 /* central meridian
41 45 0.000 /* latitude of projection's origin 400000.00000 /* false easting (meters) 0.00000 /* false northing (meters)However, after the file is imported and I run r.info on the map I see:
Type of Map: raster Number of Categories: 5729 Data Type: CELL
Rows: 18724
Columns: 24657
Total Cells: 461677668
Projection: Lambert Conformal Conic
N: 1735231.43724681 S: 1120657.1324816 Res: 32.82281055
E: 952979.22944945 W: 143667.18968253 Res: 32.82281055I cannot seem to be able to convert from feet to meters during the import.
If I followed your post correctly, you should not be converting anything during the inport. You import into a Location defined with projection params exactly like the original ArcInfo file.
Then create a new, empty Location with units meters. Switch to the new location, import the region vector polygon (from v.in.region in the original Location), and set the region to that vector.
Now you should be ready to do r.proj to re-project the original (feet) raster to the new region with units=meters.
The command used was:
r.in.gdal -o input="/usr4/Oregon/dem10-nw/hdr.adf" output="demNW10"What have I missed here?
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
