[GRASS-user] Proper Use of r.random and v.surf.rst
   Trying to follow the GRASS Book (page 292ff) to resample my 10m DEM to 5m
resolution using generation of random points and RST spline interpolation I
fail to get usable results.
   The input DEM has about 5000 cols and 5500 rows; a huge number of cells.
After waiting a long time for processing with 1 million plus points and
learning that 2G of RAM are insuffient for that many points, I settled on
100,000 points. The command used was:
r.random in=aberDEM n=100000 vector_out=aber10rand --o
   When that finished I invoked:
v.surf.rst in=aber10rand elev=elev10rand.def --o
using the defaults for v.surf.rst.
   When it finally finishes and I display elev10rand.def I get broad
horizontal color bands, from blue on the top to dark brown on the bottom.
   What have I done incorrectly?
Rich
   Think I found my error: not restting the resolution to 5m prior to running
the module. It's working away now on what I hope is the proper use.
Rich
   My latest attempt (which ran most of the night) did not produce the
desired results. I've dropped the attempt for lack of time.
Rich
