[GRASS-user] Proxy Authorization Required Error
Dear Grass Users,
I am a new GRASS user and I installed few days ago the 7.2 Version on WIN7 64bit.
I am trying to install some of the extensions using “install extension addons”. The tool does not connect to the repository and it finds therefore no extensions.
As alternative, I used g.extension. In this case I receive the error 407 “Proxy Authorization Required”. I looked for some solution online but I didn’t find any clear and easy-to-apply solution.
Following I report the complete error message of g.extensions.
Can anybody suggest a solution?
Best Regards
Francesco
(Fri Jan 20 15:27:45 2017)
g.extension extension=exstension=r.geomorphon operation=add
Downloading precompiled GRASS Addons <exstension=r.geomorphon>…
File "C:\PROGRA~1\QGIS2~1.18\apps\grass\grass-7.2.0/script
s/g.extension.py", line 1730, in
sys.exit(main())
s/g.extension.py", line 1709, in main
install_extension(source=source, url=url, xmlurl=xmlurl)
s/g.extension.py", line 680, in install_extension
ret += install_extension_win(module)
s/g.extension.py", line 953, in install_extension_win
outdev=outdev, directory=srcdir, tmpdir=TMPDIR)
s/g.extension.py", line 1094, in download_source_code
f, h = urlretrieve(url, zip_name)
File “C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\urllib.py”,
line 94, in urlretrieve
return _urlopener.retrieve(url, filename, reporthook,
data)
line 240, in retrieve
fp = self.open(url, data)
line 208, in open
return getattr(self, name)(url)
line 359, in open_http
return self.http_error(url, fp, errcode, errmsg,
headers)
line 372, in http_error
result = method(url, fp, errcode, errmsg, headers)
line 711, in http_error_407
line 381, in http_error_default
raise IOError, (‘http error’, errcode, errmsg, headers)
IOError: (‘http error’, 407, ‘Proxy Authorization Required’,
<httplib.HTTPMessage instance at 0x00000000026CD748>)
(Fri Jan 20 15:27:46 2017) Command finished (0 sec)
On Wed, Jan 25, 2017 at 3:21 AM, Mascioli, Francesco <
Hi, did you try
https://grass.osgeo.org/grass72/manuals/g.extension#
download-and-install-of-an-extension-when-behind-a-proxy
Vaclav
