[GRASS-user] ps.map: add classified vector layers to map?
Hi list,
ps.map does a great job when printing maps without classification. But what is the best way to create a map with - let's say - two vector layers which should be divided into classes? I can only specify cat-values to be displayed or not, but not ranges of values for other columns (normally, I would say, I do not know the cat-values I would like to display, but e.g. the ranges of column1, column2).
Is there a good approach for this? Experiences with this matter? ps.map is the only possibility for me to produce high-quality-maps at the moment, as the printing functionality of QGIS is not developed that far.
I would really appreciate any ideas on this question!
Best,
Wolfgang
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
On 18/01/07 18:12, Wolfgang Qual wrote:
Hi list,
use the 'where' clause
If you want to see an example, just run d.vect.thematic and tell it to create a ps.map file (if you're using GIS Manager, just fill in the 'Name for ps.map instruction files' text field.
Use the 'label' clause to create a label (d.vect.thematic does automatically) and the vlegend to display your classes in the legend.
Moritz
Hi Moritz,
thank you very much! This helps..
Best regards,
Wolfgang
Am Freitag 19 Januar 2007 pH:37:09 vormittags schrieb Moritz Lennert:
> Hi list,
> the ranges of column1, column2). Is there a good approach for this?
Moritz
