[GRASS-user] ps.map in scripts?
Can I run ps.map non-interactively, like, inside a shell script?
thanks
Carlos
Carlos Henrique Grohmann - Guano
Visiting Researcher at Kingston University London - UK
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
“Good morning, doctors. I have taken the liberty of removing Windows 95 from my hard drive.”
–The winning entry in a “What were HAL’s first words” contest judged by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can’t stop the signal.
yes: ps.map in=instructions.file out=map.ps
Attached an example script which uses the possibility of using d.vect.thematic to create a ps.map command file, which is then amended before running ps.map on it. (the script allows use of other classification schemes than those currently present in d.vect.thematic - and yes, I know I promised a C-version of d.vect.thematic...still on my ToDo list).
Moritz
(attachments)
indics.sh (1.92 KB)
Many thanks!
and yes, I know I promised a C-version of d.vect.thematic…still on my
ToDo list).
Moritz
