[GRASS-user] ps.map rotation of symbols based upon DB column
I would like to make a geological map, with strike-dip symbols (orientation of planes). I was wondering whether is was possible to rotate point symbols (using vpoints) based upon a db-column (like the size - sizecol option for vpoints), since a map generally contains a lot of strike-dip symbols and entering every position and orientation of each symbol by hand is rather tedious?
   Willem van Mierlo
It's a nice idea, give me a few minutes....
Hamish
Hello!
This would be a great thing! Especially if it could be possible not only to rotate sysmbols, but also to oroentate them! This would be very helpful for making geomorphological maps, too.
So, if you have the patience to think some minutes more, I would try to be a testing person!
Greetings
Manuel
please visit www.warela.eu
and participate:
WaReLa scientific conference on
Integrated catchment management
for hazard mitigation
September 24-26, 2007 in Trier, Germany
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent Scientific Assistant
Physische Geographie Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften Geography/Geosciences
Universität Trier University of Trier
D - 54286 Trier
Tel.: +49-651-201 4557
Fax: +49-651-201 3976
Web: http://www.uni-trier.de/uni/fb6/geographie/mitarbeiter/Seeger/
done in 6.3cvs: ps.map's vpoints instruction now has a rotatecolumn
option which works like rgbcolumn and sizecolumn. Rotation is measured in
degrees CCW. Screenshot attached (using as rotation val v.mkgrid cat*5).
It should work for EPS symbols/patterns as well:
  http://grass.gdf-hannover.de/wiki/AreaFillPatterns
New and only lightly tested, so I may have broken something. Note you can
use rotatecolumn, rgbcolumn, and sizecolumn all at the same time, maybe
to do some interesting multivariate thematic vector mapping.
I'd be interested in seeing how your strike-dip map comes out.
One thing I notice is that we may want an arrow symbol with a slightly
longer tail to it. see what I mean:
  http://grass.gdf-hannover.de/wiki/IconSymbols#Existing_symbols
or just modify arrow1,arrow2?
enjoy,
Hamish
(attachments)
Hi Hamish,
thanks for the very quick response! I will give it a shot later today!
Willem.
Hamish wrote:
