On Mon, 15 May 2023, Vaclav Petras wrote:
The r:g:b format supports 0-255, not the hexadecimal colors, so that's why
ff does not work. With display commands, you can also use #rrggbb
(#RRGGBB). I would have to check if that works with ps.map or not.
Vaclav,
I should know that. Perhaps need to recaffinate. Yes, the color chart I used
has hexidecimal numbers.
Many thanks,
Rich
