[GRASS-user] ps.map vlegend name
I looked around but couldn’t find the answer to my particular problem. I’m generating PS maps using the ps.map functionality and use the vlegend to add a legend. However, each layer name also includes PERMANENT. How can I remove this from the name?
For example, my layer name is roads but when the legend if produced, it prints: roads (PERMANENT).
I presume it’s because the vectors were saved in PERMANENT, but how can I remove it from the legend when producing my PS map?
Thanks in advance and have a great day,
Conrad
Conrad Bielski:
Hi Conrad,
I looked around but couldn't find the answer to my particular problem. I'm generating PS maps using the ps.map functionality and use the vlegend to add a legend. However, each layer name also includes PERMANENT. How can I remove this from the name?
I presume it's because the vectors were saved in PERMANENT, but how can I remove it from the legend when producing my PS map?
Thanks in advance and have a great day,Conrad
Did you check for the `label`? From the manual
(https://grass.osgeo.org/grass70/manuals/ps.map.html#vlegend):
label - for description in vlegend. Default is: map(mapset);
Nikos
Thanks Nikos,
I’m sure that’s the solution (will test today). But the docs don’t describe the ‘label’ parameter in the vlegend section. That’s probably why I didn’t notice it…
Otherwise, the docs are great!
Have a great day,
Conrad
To: Conrad Bielski conrad_bielski@yahoo.com
Cc:grass-user@lists.osgeo.orggrass-user@lists.osgeo.org
Sent: Wednesday, October 5, 2016 11:44 PM
Subject: Re: [GRASS-user] ps.map vlegend name
Conrad Bielski:
Hi Conrad,
Did you check for the label? From the manual
Nikos
