When using "area fill patterns" (http://grass.osgeo.org/wiki/AreaFillPatterns#Example_Pattern_files) together with vlegend in ps.map trouble appears when customising the patterns to my need. You can pretty much get the patterns you desire with the aid of pwith and scale option, but the problem is that vlegend does not follow up. Vlegend somewhat scales things down making the legend lock like something else than what is seen in the map. One can change the size of the legend by using width and fontsize but the pattern will still have the same size.
Is there any solution to this problem other than generating your own legend?
your own legend?
please file it as a wish/bug in the trac system. I might not be
able to look at it for a few weeks, but don't want it to get
forgotten about.
I've seen something like this before and I figured out a fix for
it, but I'll have to remind myself how I did that.
I started making my own legend, but I can't seem to make one with pattern The rectangle function does not accept a pat command. Any workaround or ideas?
Martin
-----Opprinnelig melding-----
Fra: Hamish [mailto:hamish_b@yahoo.com]
Sendt: 3. mars 2011 02:29
Til: grass-user@lists.osgeo.org; Martin Album Ytre-Eide
Emne: Re: [GRASS-user] Ps.map vlegend
have the same size.
legend?
please file it as a wish/bug in the trac system. I might not be able to look at it for a few weeks, but don't want it to get forgotten about.
I've seen something like this before and I figured out a fix for it, but I'll have to remind myself how I did that.
ideas?
one idea: try adding clone vareas, but with smaller pwidth and
an impossible SQL where clause so nothing is ever drawn to the
map. Then use those mini-patterns in the vlegend.
Use 'lpos 0' for the real areas so that they don't get added
to the legend.
if you are comfortable tweaking and recompiling C code there are
other options...
sorry, use scale*2 with that, not pwidth (pattern line width)
and an impossible SQL where clause so nothing is ever drawn to
the map. Then use those mini-patterns in the vlegend.
added to the legend.
there are other options...
the patch I posted was wrong, this one will remove the probably-too much
pattern shrinking in the vector legend:
