[GRASS-user] pygrass : creation of an area in a vector map
Hello all,
I’m trying to write a new area to a new vector map, without success.
If I do the following :
new_boundary = Boundary(points=coordinates)
new_centroid = Point(point_x,point_y)
new_area = Area(boundary = new_boundary, centroid=new_centroid)
new_vect_map.write(new_area)
I get this error:
AttributeError: ‘VectorTopo’ object has no attribute ‘_write_area’
But if I write the boundary and centroids independently, the areas are not properly created, and centroids are just recognized as “points”, not centroids.
I should I proceed to have the vector map properly written?
Below is my version of GRASS:
GRASS 7.0.0svn (2014)
libgis Revision: 62395
libgis Date: 2014-10-26 18:17:27 -0600 (dom 26 de oct de 2014)
Laurent
Hi Laurent,
On Tue, Dec 9, 2014 at 9:13 PM, Laurent C. <lrntct@gmail.com> wrote:
I'm trying to write a new area to a new vector map, without success.
I have no solution for that right now. At the moment you can only read
the areas.
I get this error:
AttributeError: 'VectorTopo' object has no attribute '_write_area'
properly created, and centroids are just recognized as "points", not
centroids.
You should go a step inside the C API of GRASS through ctypes and
write your own function, I was not directly interested on write areas
and therefore as far as I no, there is not an high level interface to
do this task.
Probably there is some error when pygrass write the centroids that are
just simple points without the topology meaning...
All the best
Pietro
