martinl
1
how to call in pygrass modules like `v.to.db`?
from grass.pygrass.modules.shortcuts import vector as v
v.to.db(map='p5', option='area', column='vymera_ha', units='hectares')
fails
File "/opt/src/grass70_release/dist.x86_64-unknown-linux-gnu/etc/python/grass/pygrass/modules/interface/module.py",
line 289, in __init__
raise GrassError(str_err % self.name)
grass.pygrass.errors.GrassError: u'Error running: `v.db
--interface-description`.'
Thanks, Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
On Tue, Oct 21, 2014 at 6:31 PM, Martin Landa <landa.martin@gmail.com>
wrote:
isn't it v.to_db?
Anna
fails
File
Thanks, Martin
grass-user mailing list
grass-user@lists.osgeo.org
2014-10-22 3:26 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
isn't it v.to_db?
I am getting the same error. Martin
On Wed, Oct 22, 2014 at 10:24 AM, Martin Landa <landa.martin@gmail.com> wrote:
isn't it v.to_db?
I can not reproduce your error:
v2db = v.to.db
OSError error(2): No such file or directory
[cut]
GrassError: Error running: `v.to --interface-description`.
v2db = v.to_db
I'm using an old version of grass70 (r60913), but I can not update at
the moment because I'm travelling...
I will check as soon as I arrive at home.
Pietro
ok, I compiled at the latest version of release 70 (r62357), and still
I have no problems to use and call the module with: v.to_db.
