[GRASS-user] python commands on grass.
Dear all,
is there a way of I know the commands available on python grass library?
Checking the codes available at https://svn.osgeo.org/grass/grass/trunk/script
(thanks Martin) I saw the following commands:
grass.read_command
grass.parse_key_val
grass.run_command
grass.message
grass.fatal
By the way, how can I know the methods / parameters for each command?
Meanwhile, I can run g.list with the command bellow, but I can’t
deal with the name of each of my raster map. In fact I receive the
same output as in gis.m console, but I would like only receive a list of
maps as output.
rasterfiles = grass.read_command(‘g.list’,type=‘rast’)
milton
2009/5/5 Milton Cezar Ribeiro <miltinho.astronauta@gmail.com>:
grass.py is located in
lib/python
e.g.
https://svn.osgeo.org/grass/grass/trunk/lib/python/
It's best documentation :slight_smile:
Meanwhile, I can run g.list with the command bellow, but I can't
maps as output.
rasterfiles = grass.read_command('g.list',type='rast')
use
grass.mlist_grouped(type = 'rast')
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Try using help() from within the python shell.
python
import grass
help(grass)
-Jamie
On Tue, May 5, 2009 at 11:52 AM, Milton Cezar Ribeiro <miltinho.astronauta@gmail.com> wrote:
Dear all,
grass.read_command
grass.parse_key_val
grass.run_command
grass.message
grass.fatal
maps as output.
milton
grass-user mailing list
grass-user@lists.osgeo.org
On Tue, May 5, 2009 at 8:57 PM, Martin Landa <landa.martin@gmail.com> wrote:
lib/python
e.g.
and now there is even more (I have doxygenized the docs):
http://download.osgeo.org/grass/grass6_progman/
-> Further libraries
   -> python: GRASS 6 Python library
Improvements to the page are welcome, the file to edit is here:
http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/lib/python/grasspythonlib.dox
cheers
