Just to know if this is a common problem. Every time I start grass python flags for an error warning me that it stopped working. GRASS itself continues working without any problem, but the python error box keeps appearing.
I guess this has to do with this version of GRASS being unstable, unless it happens only to me, in which case, it is more serious hehe
So, how common is this error? Does it happen with you?
On Mon, Jan 6, 2014 at 10:41 AM, Nuno Sá <nunocesardesa@gmail.com> wrote:
Hello!
appearing.
Is there only the message that it stopped working? No more details?
It is more about how to get Python applications working on Windows
It would be great to get a bit more details about the error.
All the description I can get from the error is what is in the picture. Is there any other way to get a more detailed report from errors in windows 8? if there is, tell me and I will try.
In this case, I am just forcing the error by trying to install an extension (which I really actually need, i.landsat.dehaze).
This case its a killer, it says its “unable to load extensions”. I guess it might also be because I am using the 7 version.
appearing.
appearing.
appearing.
