Hello. In previous (win)grass versions I was able to work with r.landscape.evol addon. Now with 7.8.2 wingrass version appears a python NameError:
r.landscape.evol elev=DEM_21x21@PERMANENT initbdrk=0 smoothing=no prefx=levol_test outdem=elevation_test outsoil=soildepth_test number=1
File "C:\Users\USUARIO\AppData\Roaming\GRASS7\addons/scrip
ts/r.landscape.evol.py", line 665, in
f = file(statsout, ‘wt’)
NameError: name ‘file’ is not defined
It seems that the script was written in Python < 3 and ‘file()’ is not supported in Python 3. Is possible that the addon needs to transform into valid Python 3.x code?
Thanks for your help!
NameError:
*r.landscape.evol elev=DEM_21x21@PERMANENT initbdrk=0 smoothing=no
prefx=levol_test outdem=elevation_test outsoil=soildepth_test number=1*
*Traceback (most recent call last):*
* File "C:\Users\USUARIO\AppData\Roaming\GRASS7\addons/scrip*
*ts/r.landscape.evol.py <http://r.landscape.evol.py/>", line 665, in
<module>
* f = file(statsout, 'wt')*
*NameError: name 'file' is not defined*
some hints e.g. here:
https://stackoverflow.com/questions/28121163/python-3-doesnt-have-the-file-function/28121192
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
NameError:
<module>
grass-user mailing list
grass-user@.osgeo
I opened an issue here:
https://github.com/OSGeo/grass-addons/issues/156
Just comment or if you have a solution, open a PR there
best regards
Helmut
