I just tested it again and realized this problem is
not related to the placeholder in the python code,
but probably an other issue of my pythoncode line
nothing is update when use:
grass.write_command("db.execute", stdin = "UPDATE my points
SET prob=100")
but using UPDATE my points SET prob=100 in the module GUI
works as mentioned already before.
Has anyone experience in using db.execute in python with
standard input in GRASS7?
in GRASS7 you need to add "input=-" as an option to trigger
reading input stdin. (or else stalled module gui headaches..)
perhaps this needs to be changed to YES?
input->required = NO;
SET prob=100")
No, because db.execute sql=<SQL statement> works just fine, input is
not required.
Thank you Hamish, including the option “input=-” in the python line (for GRASS7) solved the problem.
Now I get an update/entry in my attribute table. This is a different behavior from
grass65 where this additional option is not needed.
grass.write_command(“db.execute”, stdin = “UPDATE my points
SET prob=100”)
in GRASS7 you need to add “input=-” as an option to trigger
reading input stdin. (or else stalled module gui headaches…)
No, because db.execute sql= works just fine, input is
not required.
