[GRASS-user] Python script
  I'm trying to use r.stats via the python shell inside GRASS but I'm
getting an error that I do not know how to solve. The code I'm using is
this:
grass.run_command('r.stats',input=inp,output='D:\\CropScape\\2012_cdls\\AZ.c
sv',flags = 'ani')
I already tried the following variables for input:
inp=['AZ','COUNTIES']
inp=['AZ@PERMANENT ','COUNTIES@PERMANENT']
inp=['D:\\CropScape\\2012_cdls\\AZ.tif',
'D:\\CropScape\\Counties\\COUNTIES.tif']
Every time I get the same error: " GRASS_INFO_ERROR(1444,1): Raster map
<D:\CropScape\2012_cdls\AZ.tif> not found"
Any idea of what could be?
  Pedro
this:
sv',flags = 'ani')
Either of these should work, provided that you actually have maps with
those names in the PERMANENT mapset.
The inputs must be map names, not filenames.
Have you actually created the maps? You cannot use an image file as a
map without first either importing it (with e.g. r.in.gdal) or linking
it (with r.external).
