Hi guys,
I'm starting to use Python to run an analysis that should take
several hours to process (a few minutes for each individual analysis, that
is why scripting is the way to go) but I'm getting some pretty weird errors
(using the shell inside the GUI).
So I'll start my questions from the beginning:
- Which is the python library from Grass that I have to reference? I
did not find any library called grass.py (which I'd guess would be called
given how one references it inside the python shell in Grass)
- Testing the exec_command inside grass' python shell I get the
following:
grass.exec_command('r.stats', flags='', quiet=True, verbose=False, env=None,
input='FAZ_Raster@PERMANENT,CA2010@PERMANENT',
output='C:\Users\Pedro\Downloads\GRASS\California2010\StatsO.txt')
File "<input>", line 1, in <module>
File
"C:\PROGRA~2\QUANTU~1\apps\grass\grass-6.4.2\etc\python\grass\script\core.py
", line 312, in exec_command
os.execvpe(prog, args, env)
File "C:\PROGRA~2\QUANTU~1\apps\Python27\lib\os.py", line 353, in execvpe
_execvpe(file, args, env)
File "C:\PROGRA~2\QUANTU~1\apps\Python27\lib\os.py", line 380, in _execvpe
func(fullname, *argrest)
OSError: [Errno 2] No such file or directory
Any ideas on where the error might be?
Thanks again,
Pedro
