GRASS 6.4.0RC6 (sa_wgs84):~ > ls *.py
check_3d.py proxy.py
GRASS 6.4.0RC6 (sa_wgs84):~ > check_3d.py
check_3d.py: command not found
Try "python check_3d.py" or copy the script under the "scripts" directory in
your local grass installation (somethin' lke
"/usr/local/grass-6.4.0svn/scripts").
I also tried placing the script in the GRASS scripts folder using the
name 'v.check3d' and got the following errors:
A, ok! You already did that.
GRASS 6.4.0RC6 (sa_wgs84):~ > v.check3d
bash: /usr/lib/grass64/scripts/v.check3d: Permission denied
GRASS 6.4.0RC6 (sa_wgs84):~ > sudo v.check3d
[sudo] password for hanlie:
sudo: v.check3d: command not found
Better not to use sudo (as a general advice). The script needs to be made
executable for your user-name, i.e.:
On Thursday 19 of August 2010 15:47:13 Hanlie Pretorius wrote:
2010/8/19, Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
> sudo chown hanlie:hanlie v.check3d
Ran 'sudo chown hanlie:hanlie v.check3d' from the
/usr/lib/grass64/scripts directory with no error messages, but GRASS
still gives a permission error:
In Ubuntu, you can right click on the file and tick the box to make it
executable....
Right Click > Properties > Permissions
Allow executing files as program
executable....
Sab
Thanks, tried this and it workedfor the script in the
/usr/lib/grass64/scripts folder.
