[GRASS-user] Python scripts- How to call external bin
Greetings
I want to integrate in a Python script a call to an external binary (a small fucntion that I have done). What can i use to do this?
Thanks
Kat
The standard Python functions for spawning child processes are
subprocess.Popen() and subprocess.call()
  http://docs.python.org/library/subprocess.html
The grass.script module has its own versions of these functions, which
set shell=True on Windows so that scripts work, but that doesn't
matter if you're running a binary executable. It also has several
functions which are intended specifically for running GRASS modules
(anything that uses the GRASS command-line parser).
Hello Glynn
Just one question: I reading http://grass.osgeo.org/programming6/pythonlib.html the "GRASS-oriented interface to subprocess module" and I’m wondering wich one of this functions shall i use to run an external bin in Windows? run_command?
Thanks
2011/7/1 Glynn Clements <glynn@gclements.plus.com>
set shell=True on Windows so that scripts work, but that doesn’t
matter if you’re running a binary executable. It also has several
http://grass.osgeo.org/programming6/pythonlib.html the "*GRASS-oriented
interface to subprocess module" and I'm wondering wich one of this functions
shall i use to run an external bin in Windows? run_command?*
Does the external program use the GRASS parser? If it doesn't, you
shouldn't use any of those functions; just use subprocess.Popen().
If it uses the parser, then the correct command to use depends upon
how you wish to interact with the child process. Read each of their
descriptions to determine which is appropriate.
All of them (except for exec_command) are simple wrappers around
start_command, which itself just uses make_command to construct a
suitable argument list to pass to Popen().
Hello
In this case is an external binary written in C. So I will shall use the subprocess.Popen() right?. Besides that general page you gave me, do you know any other page that explains, in a easier way, thje use and parameterizayion of subprocess.Popen()?
Thanks
Kat
2011/7/4 Glynn Clements <glynn@gclements.plus.com>
http://grass.osgeo.org/programming6/pythonlib.html the “*GRASS-oriented
interface to subprocess module” and I’m wondering wich one of this functions
Does the external program use the GRASS parser? If it doesn’t, you
shouldn’t use any of those functions; just use subprocess.Popen().
Not a very happy observation but did you look at the Subprocess manual
page on the Python web site? This is the main reference for the
module...
On Mon, Jul 4, 2011 at 6:29 PM, katrin eggert
<katrineggert1980@gmail.com> wrote:
Hello
Thanks
Kat
> functions
grass-user mailing list
grass-user@lists.osgeo.org
No.
