Greetings
I’m doing a processing that requires setting rules such as : IF band1> 1 output=5 if band<=1 ouput= 3 and if band2>5 output=7. How can I do this in a Python script in order to be “almost automatic”?
Thanks
Best regards
Luisa
Greetings
Thanks
Best regards
Luisa
2010/6/22 Luisa Peña <luisapena1979@gmail.com>:
Greetings
I'm doing a processing that requires setting rules such as : IF band1> 1
Python script in order to be "almost automatic"?
if band1 > 1:
output = 5
else:
output = 3
if band2 > 5:
output = 7
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Hi Martin
Maybe I was not clear enough. this is a procedding to be done over each pixel. Can I apply this sort of code to a pixel based analysis?
2010/6/22 Martin Landa <landa.martin@gmail.com>
Greetings
Python script in order to be “almost automatic”?if band1 > 1:
output = 5
else:
output = 3if band2 > 5:
output = 7Martin
mapcalc() from grass.script.raster [1] or try ctypes interface from trunk.
Martin
Hi Martin
Thanks
You mean like using an expression, for mapcalc, based on ifs right? Is this interface available for GRASS6.4? If so, is there an example of usage?
And about the ctypes interface? What is it? can it work on GRASS6.4.0 RC6?
Thanks
Luisa
pixel. Can I apply this sort of code to a pixel based analysis?mapcalc() from grass.script.raster [1] or try ctypes interface from trunk.
Martin
Hi Martin
Thanks
Thanks
Luisa
Martin
