[GRASS-user] QGIS + GRASS GIS console
QGIS + GRASS GIS 7.8.2, in Windows 10, 64 OS, not working, when computed a DTM from QGIS “TIN interpolation”, followed bi “r.fill.dir”:
QGIS version: 3.12.0-București
QGIS code revision: cd141490ec
Qt version: 5.11.2
GDAL version: 3.0.4
GEOS version: 3.8.1-CAPI-1.13.3
PROJ version: Rel. 6.3.1, February 10th, 2020
Processing algorithm…
Algorithm ‘r.fill.dir’ starting…
Input parameters:
{ ‘-f’ : False, ‘GRASS_RASTER_FORMAT_META’ : ‘’, ‘GRASS_RASTER_FORMAT_OPT’ : ‘’, ‘GRASS_REGION_CELLSIZE_PARAMETER’ : 0, ‘GRASS_REGION_PARAMETER’ : None, ‘areas’ : ‘TEMPORARY_OUTPUT’, ‘direction’ : ‘TEMPORARY_OUTPUT’, ‘format’ : 0, ‘input’ : ‘H:/FICHEIROS_DADOS/CARTOGRAFIA/MNT/MNT_1415/MNT_10K_2011/EPSG_3763/MDE_QGIS/mde2geral.tif’, ‘output’ : ‘TEMPORARY_OUTPUT’ }
g.proj -c proj4=“+proj=tmerc +lat_0=39.6682583333333 +lon_0=-8.13310833333333 +k=1 +x_0=0 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs”
r.in.gdal input=“H:\FICHEIROS_DADOS\CARTOGRAFIA\MNT\MNT_1415\MNT_10K_2011\EPSG_3763\MDE_QGIS\mde2geral.tif” band=1 output=“rast_5e78c95a53bf92” --overwrite -o
g.region n=-55000.37998979999 s=-80000.43 e=-31998.2197489 w=-63998.17 res=4.9992111
r.fill.dir input=rast_5e78c95a53bf92 format=“grass” output=output9c34ebfb2d204df1afd1d27147a3522b direction=direction9c34ebfb2d204df1afd1d27147a3522b areas=areas9c34ebfb2d204df1afd1d27147a3522b --overwrite
g.region raster=output9c34ebfb2d204df1afd1d27147a3522b
r.out.gdal -t -m input=“output9c34ebfb2d204df1afd1d27147a3522b” output=“C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\0081688cca90464486f44241eca07462\output.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
g.region raster=direction9c34ebfb2d204df1afd1d27147a3522b
r.out.gdal -t -m input=“direction9c34ebfb2d204df1afd1d27147a3522b” output=“C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\54bb8b8a97534d53a90cfaa02ea9a703\direction.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
g.region raster=areas9c34ebfb2d204df1afd1d27147a3522b
r.out.gdal -t -m input=“areas9c34ebfb2d204df1afd1d27147a3522b” output=“C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\734c1979cfb44de098ebea2a6ab5aad3\areas.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
Starting GRASS GIS…
WARNING: Concurrent mapset locking is not supported on Windows
Cleaning up temporary files…
Executing <C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\grassdata\grass_batch_job.cmd> …
C:\Users\Particular\Documents>chcp 1252 1>NUL
C:\Users\Particular\Documents>g.proj -c proj4=“+proj=tmerc +lat_0=39.6682583333333 +lon_0=-8.13310833333333 +k=1 +x_0=0 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs”
Default region was updated to the new projection, but if you have multiple mapsets g.region -d should be run in each to update the region from the default
Projection information updated
C:\Users\Particular\Documents>r.in.gdal input=“H:\FICHEIROS_DADOS\CARTOGRAFIA\MNT\MNT_1415\MNT_10K_2011\EPSG_3763\MDE_QGIS\mde2geral.tif” band=1 output=“rast_5e78c95a53bf92” --overwrite -o
Over-riding projection check
Importing raster map <rast_5e78c95a53bf92>…
0…3…6…9…12…15…18…21…24…27…30…33…36…39…42…45…48…51…54…57…60…63…66…69…72…75…78…81…84…87…90…93…96…99…100
C:\Users\Particular\Documents>g.region n=-55000.37998979999 s=-80000.43 e=-31998.2197489 w=-63998.17 res=4.9992111
C:\Users\Particular\Documents>r.fill.dir input=rast_5e78c95a53bf92 format=“grass” output=output9c34ebfb2d204df1afd1d27147a3522b direction=direction9c34ebfb2d204df1afd1d27147a3522b areas=areas9c34ebfb2d204df1afd1d27147a3522b --overwrite
C:\Users\Particular\Documents>g.region raster=output9c34ebfb2d204df1afd1d27147a3522b
ERROR: Raster map not found
C:\Users\Particular\Documents>r.out.gdal -t -m input=“output9c34ebfb2d204df1afd1d27147a3522b” output=“C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\0081688cca90464486f44241eca07462\output.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
ERROR: Raster map or group not found
C:\Users\Particular\Documents>g.region raster=direction9c34ebfb2d204df1afd1d27147a3522b
C:\Users\Particular\Documents>r.out.gdal -t -m input=“direction9c34ebfb2d204df1afd1d27147a3522b” output=“C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\54bb8b8a97534d53a90cfaa02ea9a703\direction.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
C:\Users\Particular\Documents>g.region raster=areas9c34ebfb2d204df1afd1d27147a3522b
C:\Users\Particular\Documents>r.out.gdal -t -m input=“areas9c34ebfb2d204df1afd1d27147a3522b” output=“C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\734c1979cfb44de098ebea2a6ab5aad3\areas.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
C:\Users\Particular\Documents>exit
Execution of <C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\grassdata\grass_batch_job.cmd> finished.
Press any key to continue . . .
Execution completed in 62.54 seconds
Results:
{‘areas’: <QgsProcessingOutputLayerDefinition {‘sink’:TEMPORARY_OUTPUT, ‘createOptions’: {‘fileEncoding’: ‘System’}}>,
‘direction’: <QgsProcessingOutputLayerDefinition {‘sink’:TEMPORARY_OUTPUT, ‘createOptions’: {‘fileEncoding’: ‘System’}}>,
‘output’: <QgsProcessingOutputLayerDefinition {‘sink’:TEMPORARY_OUTPUT, ‘createOptions’: {‘fileEncoding’: ‘System’}}>}
Loading resulting layers
The following layers were not correctly generated.
  • C:/Users/Particular/AppData/Local/Temp/processing_Dhabro/0081688cca90464486f44241eca07462/output.tif
  • C:/Users/Particular/AppData/Local/Temp/processing_Dhabro/54bb8b8a97534d53a90cfaa02ea9a703/direction.tif
  • C:/Users/Particular/AppData/Local/Temp/processing_Dhabro/734c1979cfb44de098ebea2a6ab5aad3/areas.tif
You can check the ‘Log Messages Panel’ in QGIS main window to find more information about the execution of the algorithm.
What should be?
Thanks in advance
Cumprimentos,
Valter Albino - Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
In the first time (previous email), tried to compute “r.fill.dir” from “Processing Toolbox”. I also tried from GRASS GIS console: the output is:
C:/OSGEO4~1/apps/grass/grass78/bin/r.fill.dir.exe input=mde2geral@TRABALHOS format=grass output=mde2geralfill direction=mde2geralflowdir
Reading input elevation raster map…
Module crashed or killed
Valter Albino <valteralbino@gmail.com> escreveu no dia segunda, 23/03/2020 à(s) 14:51:
Cumprimentos,
Looks like the “TIN interpolation” raster can’t be read by the “r.fill.dir”.
Just tested in another DTM and it worked.
I used the “TIN interpolation” from QGIS because i can choose the from “structured line” and/or “break line”.
What are the alternatives?
Valter Albino <valteralbino@gmail.com> escreveu no dia segunda, 23/03/2020 à(s) 15:16:
Cumprimentos,
