And when I open QGIS I get a yellow bar with the following warning:
GRASS init error: Problem in GRASS initialization, GRASS provider and plugin will not work : Module built against version $Revision: 64733 $ but trying to use version $Revision: 67364 $. You need to rebuild GRASS GIS or untangle multiple installations.
César Augusto Ramírez Franco
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias - Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 300 459 6085
QGIS was built against a earlier version of GRASS. It's only built after
release but not whenever dependencies change.
Try the our nightlies. Those are not built when dependencies change either,
but whenever there was a new commit on the branch. So there is a chance that a
QGIS update triggered a rebuild after GRASS was updated.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Thanks for your reply, however, I’d like to stay away from non-stable releases, and sadly, I tried using the QGIS-ubuntugis-ltr repo but the plugin doesn’t even install
2016-02-04 12:50 GMT-05:00 Jürgen E. <jef@norbit.de>:
Hi César,
QGIS was built against a earlier version of GRASS. It’s only built after
Jürgen
